Results 1 to 3 of 3
Thread: s/c L67 idling to high problems?
    VT Calais Supercharged V6
    Dec 2008
    Lightbulb s/c L67 idling to high problems?
    my L67 vt calais has started idling higher then normal about 1000rpm instead of the standard 800rpm the only work thats been done is a new fuel filter and i cleaned the air filter, i also found a small rubber elbow broken that goes to the boost solanoid but i fixed that apart from that i dont know whats causing it to idle high?
    Any help would be very helpfull..
    Thanks
    BIG-EV's Avatar
    BIG-EV is offline Project VT (In Progress)
    2000 VTII Executive 3.8L Supercharged V6 Wagon
    Oct 2008
    Mango Hill QLD
    it wouldn't be a vacume leak because that would make it worse.. to be honoust 1000rpm at idle aint bad mine sitts on 1000 and i have no probs it makes easyier to start when cold.
    VS l67 statesman
    Dec 2008
    My Idles about 1000 rpm but it has mods ,clean your IAC valve on the TB and see if that helps ( the plug on to of the TB goes into it and its held in with 2 Screws before you ask lol)
  1. vr idling high and ruff and missing
    By the dog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2009, 04:41 PM
  2. idling problems, open/closed loop operation, timing
    By levymetal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2009, 03:53 PM
  3. Common high KM problems?
    By MitchS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2008, 05:21 PM
  4. Car idling too high after using cruise control
    By DavidPartay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2006, 03:38 PM
  5. High Idling
    By mal62 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2006, 10:54 AM
Tags for this Thread
