Results 1 to 2 of 2
Thread: vt clutch bleed??
    VT SS 5.7 6speed
    Aug 2009
    Default vt clutch bleed??
    Can anyone tell me how to bleed the clutch in my VT 5.7 6speed??
    Smashn2nd's Avatar
    Smashn2nd is offline 330 Reasons To Drop 2nd
    VX SS LS1 S2
    Jul 2009
    Joondalup
    hey you need to get under the car and where the clutch line goes into the side of the box there is a very small hole above it. you wont be able to see it when laying down but just feel around for it, there is a small (but i think its long) nut inside there, cant remember what size it is but you need a small ratchet spanner and socket.
    now the fun part you need someones help wid it but they need to sit in the car and pump the clutch then hold it down then you crack it open, you will hear the pressure relase then close it then your mate can start pumping again, do this a few time till you have fluid dripping out the bottom of the box then all should be well, dont forget to check the little clutch bottle so it dont go empty other wise you will just be sucking in air and will have to do it all again.
    hope this helps
    VX SS LS1 6sp Manual - 330rwhp ET 13.9sec
    VS Esteem V6 Auto (clubby lookalike) - 190rwhp ET 15.7sec
    5.7L of pure torque
    The Need For Boost Is Strong
  1. Brake:Bleed
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2009, 04:45 PM
  2. VZ coolant bleed
    By shane100 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-03-2009, 03:45 PM
  3. 5L Bleed Screw - Where is it?
    By levymetal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-02-2009, 01:09 PM
  4. bleed nipples
    By Wire in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2007, 07:41 PM
  5. Make it Bleed
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2005, 04:37 PM
