hi there can the traction control be disconnected???
I think its also connected to the ABS system. you can take out the fuse but then you lose ABS too.
taking the fuse out is probly the only option, skilled drivers can brake better without abs anyway. it gets annoying having to press the trac off switch every time you start the car
yes it can be anoying but the way laws are sometimes its better to leave it on!
if you pull the fuse out and stack it kiss your insurance goodbye
