Results 1 to 10 of 10
Thread: Can someone identify what this is?
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    Default Can someone identify what this is?
    There was a hose connected to it with no hose clamps and it just pulled off with no force can someone tell me what it is and its purpose as i know it should be connected but cant find a place for it.
    help much appreciated.
    Calaber's Avatar
    Calaber is online now Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    The photos are too blurry to identify the part correctly. I can make out a heater valve and an injector, but not the bit you are concerned about. Can you take clearer pics by coming back from the object a bit when you photograph it?
    SMIT's Avatar
    Aug 2005
    Quote Originally Posted by Calaber View Post
    not really its right behind the plenum and down a bit wouldn't be able to see it if i standed back, that's why o took a few i guess i can try again.
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    I believe it will be your canister purge solenoid - required for emissions.
    It should go from the solenoid to the charcoal canister.
    The hoses normally don't have hose clamps as they normally carry vapour
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    SMIT's Avatar
    Aug 2005
    Quote Originally Posted by keza87 View Post
    i have taken everything to do with my ac out of my car. does it need to be connected? can i plug it up or put a breather on it?
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    Its not for A/C, Its for emissions and is required by law.
    JCCC NSW Member
    SMIT's Avatar
    Aug 2005
    ok i did some searching im preety sure i know what a charcoal canister looks like but dont remember seeing one in my engine bay where is it located?
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    SMIT's Avatar
    Aug 2005
    Quote Originally Posted by holdenvtman1123 View Post
    its located next to the fuel filter under the rear right of the car
    ok if that's true how come i only have about 80cm worth of hose coming of it? it wouldn't reach to the back of the car, does it connect somewhere in the engine bay?
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    yeah, theres another metal pipe next to the fuel lines on the firewall.
  1. [Buick] Identify please
    By savage1987 in forum V6 Development And Modification
    Last Post: 14-04-2009, 09:40 PM
  2. Can anyone help identify this part?
    By BigBird in forum Electrical Wiring / Questions
    Last Post: 29-12-2008, 11:48 PM
  3. how do I Identify Transmission
    By Toby in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2008, 11:28 AM
  4. Can anyone help identify this?
    By sparky in forum The Pub
    Last Post: 05-12-2006, 07:05 PM
  5. identify these EFI V8 headers
    By vkberlina in forum V8 Development and Modification
    Last Post: 09-03-2005, 09:54 PM
