Results 1 to 14 of 14
Thread: caster bar bushes? how much to get replaced?
    VT Exec
    Jan 2009
    Ballarat
    Default caster bar bushes? how much to get replaced?
    hey there today i had one of those $100 basic services on my car and the mechanic said I needed a caster bar bushes replacement because they are cracked. i was quoted $385 inc. labour.
    I was wondering is this a standard price for such a job. It seems a bit expensive however I've never had to replace them before?
    1970 AMC javelin, S2 stagea
    Jun 2008
    genuine front castor rod bushes are very pricey, better off going with a nolathane kit.
    VY SII HBD Calais L67
    Dec 2006
    Quote Originally Posted by jav360 View Post
    Spot on. Genuines or any other oil filled unit will just fail within the next couple of years anyways. Go for a urethane type replacement. Best thing on these is that they are adjustable
    VYII Calais L67
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    I got my urethene ones off eBay for less than $100, incl. postage. fitment is easy if you are keen to DIY
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by jazza15 View Post
    How did you find the ride quality after fitting urethane ones.
    I used the urethane ones in my VS and found the bump became a lot harsher.
    I'm due to replace the castor bushes in my VZ and am reluctant to use urethane (for the reason above) as I love the ride now and wouldn't want it any harder.
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Haven't been driving for the past 5 months, 2 weeks and 6 days, will let you know after 3 weeks and 1 day.
    The testing we did after fitting them however showed quite significant improvement as my old ones were stuffed. One was even bent :P
    VS ones work differently to VT - VZ ones though don't they? Well they are at least part of a different suspension setup.
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    The superpro ones are supposed to be a bit softer than nolathane, so give a bit better ride. I found them to be good quality and easy to fit. Can order these from Supercheap for something like $140.
    Put these and a strut brace on and found my steering is much more direct and controllable compared to before. Just gotta fix my steering rack now...
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I put them on my VX and found them to be ok , plus as stated you can adjust them for standard or lowered suspension . Have a look in the How to section , i done a write up there some months ago .
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    $385 is a rip off
    it is a 30min job
    just do it your self
    I did mine 2 weeks ago
    $100 for the bushes and $110 for wheel alignment and set caster
    do the rear ones while your at it they are $32
    cheers GM
    VT Series 1 V6
    Jan 2008
    I can't believe $385!!
    I got my nolathane ones off ebay for $32 final bid. They took 15 mins to install both sides start to finish, easy job and the instructions were easy to follow. All I needed was bearing grease and a wheel alignment after, so I guess $80 all up with the alignment.
    MkyHnly's Avatar
    MkyHnly is offline Finally enjoying my P's!
    VT S Pack - VC SL/E 253
    Jun 2009
    Croydon, VIC
    yeah i know it is a bit of a thread dig... but
    apparently i need to get my caster bar bushes replaced (am i right in saying this? it gives a horrible clunking noise in my front passenger wheel arch)
    if i get the bushes for my vt, how easy is it to replace these? i would much rather do the work by myself than pay $300 for a mechanic to do it!
    any help would be appreciated, cheers!
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Quote Originally Posted by MkyHnly View Post
    Depends if it's the front or rear Radius rod bush(That's what they are called)... Question:- Is the sound there while driving or while stationary and you turn the steering wheel?
    MkyHnly's Avatar
    Jun 2009
    Croydon, VIC
    it is whenever i turn the steering wheel while moving slowly (that gives a more squeak/slippy noise - its hard to explain) and whenever i go over bumps it gives a metal on metal clunk. the clunk mostly occurs when i havent driven in a while or the car is cold - if i have driven a lot in one day it rarely clunks
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by GMMAD View Post
    are the back any hard to do then the front? also have you got a part number?
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
  1. [VR-VS] HOWTO VRVS Caster Radius Z bar/rod Bushes
    By DannyboyDS in forum Holden Commodore How-To's
    Last Post: 01-03-2012, 11:34 PM
  2. Replaced radius rod bushes and link pins, still clunking?
    By VT97 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 04:14 PM
  3. Caster bar bushes and rear cross member bushes
    By Galixia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2008, 08:32 PM
  4. caster rod bushes??
    By jerzey1234555 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2006, 02:23 PM
  5. VP Caster
    By sgo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2005, 09:48 PM
