Results 1 to 14 of 14
Thread: Undoing top strut bolt
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    Default Undoing top strut bolt
    ok guys, iv got a set of SL springs to drop into the front of my vt, had everything off today last bolt i had was the top bolt in the engine bay, no matter how hard i try, no way in hell is it coming off, wd40 etc has all been tried.
    Is it essential to use spring clamps to get that top bolt off? or is it just so stupidly stuck i broke my 3 sidchrome spanners for no reason
    2000 VT S Tiga Mica
    Jun 2008
    vic,melbourne
    hey mate,
    i used a shifter to get mine off(was tight but not as tight as yours) make sure you hold the top with a 10mm spanner and then undo the big nut...hope thats what your talking about and hope it helps....
    i remember when i did mine i tryd to undo it for ages not realiseing the entire strut was just turning and i couldnt undo it no matter how hard i tried...then i got the 10m to hold the top and worked a treat....
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    yeah thats what im doing, 10mm on the top one and undoing the lower bigger nut, im having no luck at all. Need to get more leverage some how
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    theres a method of using dry ice in a can(you can buy it at auto shops) and u spray it onto the bolt, it gets moisture into the thread on the bolt and help allow it to loosen. Normally use it if wd40 fails. goodluck though.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Spring compressors wont help.
    Only method you can use if you want to keep the standard shockie is to undo the nut.
    As mentioned, a 10mm ring spanner on the top and a 23mm ring spanner for the nut.
    Try placing the spanners within hands reach of eachother and using your hand to pry the spanners together.
    If that fails try the same method but use a loose vice to pry the spanners together.
    Jun 2005
    15/16 ring spanner on the nut, with another ring spanner connected to the end to give more leverage. cant really describe how you join them together, but hopefully you know. it involves putting the ring end of the second spanner on the open end of the first spanner.
    and i used a 10mm impact socket, with a big ratchet/braker bar on the smaller part
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by stocky View Post
    VT's are a 23mm nut man.
    Same basic procedure though
    my baby
    May 2009
    Ripcell's Avatar
    Ripcell is offline R8 FTW!!!
    324rwkw MY06 VZ R8 Maloo M6
    Apr 2006
    East Melbourne
    rattle gun may help otherwise get some tube onto the end of your spanner for more leverage
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    Quote Originally Posted by Ozzie View Post
    15/16 and 23 are as close too each other as you'll get so they will both work. Its like 1/2" next to a 12mm, if the nut is in good condition, then they will both work on a 12mm nut.
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    got them off, thanks for the help everyone, got the ones holding the spring in aswell, put spring compressors on and seemed to help, dont ask me how lol
    so 3 corners are lowered currently, one last corner and she will be sitting pretty
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by sxc_sound View Post
    Using the spring compressor takes all the tension the springs are putting on the top plate and bolts etc. The first thing I do once the strut is removed is to compress the spring, it saves it shooting out at you under the tension its got.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    2002 VX II Acclaim
    Aug 2008
    Cant help you with your problem, but you've gotta love sidchromes lifetime warranty on all of there tools against breaking
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The best way to undo that nut is to keep the car on the ground so the weight is on it. That holds the bush still while you undo the nut. Sometimes it doesn't work if it is really really tight.
    The only other way to do it is to hold the strut with a 10mm spanner and undo the nut. This can round off the top of the strut though.
    If it is out of the car already, another method requires two people. One to hold the bush with multi grips while the other undoes the nut.
    Visit my Facebook page
  1. [General] Undoing fuel lines at the firewall
    By blackbedford in forum Holden Commodore How-To's
    Last Post: 07-09-2010, 10:27 AM
  2. Undoing the belt???
    By Dragz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-05-2009, 03:13 PM
  3. Undoing fuel lines on Ecotec
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2009, 09:14 AM
  4. Undoing Cooler Lines
    Last Post: 15-11-2008, 11:46 PM
  5. undoing towbar bolts on a VL wagon
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-04-2006, 08:44 AM
