Results 1 to 13 of 13
Thread: vx calais issue
    brockee's Avatar
    brockee is offline (HOUSE OF POWER)
    VX S2 SENATOR SIG CAMMD A4
    Aug 2009
    mandurah> wa
    Default vx calais issue
    hey all we have a vx calais super6 we bought bout 3 months ago with no probs until now it has got a problem with the power steering we checked the fuse seems ok no lost of fluid an seems to be in tackd !!!! now it feels like no power stering hard to steerercould it be power ster pump on its way out or steering rack f***ed any help guys cheers
    brockee's Avatar
    Aug 2009
    mandurah> wa
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Do you have speed sensitive steering? Has the steering gone completely hard or just harder than normal. My steering goes a bit harder occasionally (like it's lost the speed sensitive part) but then I restart the car and it's fixed.
    MY RIDE
    brockee's Avatar
    Aug 2009
    mandurah> wa
    yep its a series 2 calais the power steering it sorta comes a gos is it normal 2 do that or do we need 2 get it looked at cheers mate
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Sounds like you have a problem, best get it looked at.
    MY RIDE
    vt calais
    Aug 2009
    If the power steering does not work when the car is turned on and then if you turn the ignition off then on and it works your BCM computer is about to fail. I had it happen to me.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    It must be a common fault because mine does the same thing but only when driving at low speeds on a hot day.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by darc123 View Post
    That's good to know. Hopefully mine will last for a while longer, it's only done it about 3 times in 2 years. Thanks for the information, I wasn't even aware that the BCM controlled the speed sensitive steering. Now I can tell my daughter's boyfriend what's wrong with his VY Calais.
    MY RIDE
    brockee's Avatar
    Aug 2009
    mandurah> wa
    hey all.. now power steering is hard all the time now ...its still drivable but feels like ya driven a old vn sorta thing hard 2 explain so any help pplz cheers any way for easy fix????
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Make sure your power steering/alternator/Ac belt is in good condition and isn't slipping.
    brockee's Avatar
    Aug 2009
    mandurah> wa
    blackvxgts cheers for ya pointer will check tomorrow mornin an c how we go cheers mate!!!
    VX II Calais
    May 2009
    West Sydney
    same thing happen to me bouta month ago. Got the rack replaced under warranty. S'all good now. Might be ur problem??
    Cheers Frank
    5.7L VX II Calais ,Tungsten,Vy SS Rims,Full cream leather,Twin,2.5" Redback Catback,Pacemaker 4 to 1's,5% Tint,Chromed Grille
    brockee's Avatar
    Aug 2009
    mandurah> wa
    found the prob guys reset the computer tyres where like 32kpa so pumpd up ta 40kpa drives normal now hahacheers all for ya input !!!!!!
  1. VX Calais strange overheating issue
    By marsh_e79 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2009, 02:33 PM
  2. weird VT calais climate control issue
    By muneey in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2009, 04:54 AM
  3. VK Calais Sunroof issue
    By And_ROOS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-05-2008, 08:54 AM
  4. VS Calais V6 Temperature Issue
    By Akshunhiro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2007, 11:07 PM
  5. VX Calais Dual Fuel Issue
    By jake_au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2006, 01:32 AM
