Results 1 to 9 of 9
Thread: Undo monaro light conversion
    tdog is offline slipstream
    VT 355
    Feb 2006
    Default VT 383 - Undo monaro light conversion
    Hi everyone,
    Ive bought a 98 vt exec - good news is its a 5l stroked to 383 with active manifold and all the goodies - bad news is its got monaro tail lights with the original garnish. needless to say I think this looks shit and want to return it to standard.
    I bought a set of tail lights from Auto 1 and expected it to be a straight forward change over to return them to standard. However when i took the left hand light of I got a bit of a surprise.
    Firstly there is 3 globes for the monaro's - the lights i bought only have housing for 2 - one indicator and i assume the other is the clear light. Secondly the housing for the globes themselves on the new lights is different and the globes won't twist and lock in.
    Any info on how to fix this would be great as i want to get the munro ones out as quick as possible.
    cheers,
    Mark
    lifes more fun going sideways.....
    2002 VX II Acclaim
    Aug 2008
    You;d have to swap the tail light loom with the VT ones. Previous owner would have swapped them with VX ones to do the light conversion. The loom itself is about 15cm long and runs behind the carpet in the boot. If you pull it out you will see.Im sure theres somebody on here who wants to do a conversion and would even straight swap you.
    VT 355
    Feb 2006
    VT 355
    Feb 2006
    do i need a harness for each tail light or is it a shared harness?
    VZ SV6 && 180sx
    Mar 2008
    VT 355
    Feb 2006
    VT S2 Club Kitted, VR SS, VL Executive
    Oct 2005
    Broken Hill
    Quote Originally Posted by tdog View Post
    When i changed mine im pretty sure there was a clip for each light unplug and plug in new harness.
    VT 355
    Feb 2006
    lovely sounds too easy!
    been quoted about $30 for the harness
    Oct 2005
    Broken Hill
    new or second hand? myself i would go to wreckers and take their harness's ;D cheaper
  1. Problem With Vx To Vz Monaro Front Conversion
    By Marky89 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-03-2011, 08:52 PM
  2. vt rear end conversion to monaro?
    By nathan549 in forum General
    Last Post: 15-07-2009, 09:07 PM
  3. vz monaro conversion for my vx
    Last Post: 02-11-2008, 09:33 AM
  4. Monaro Rear LED Stop Light
    By Jack87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2008, 04:17 PM
  5. how to undo the drain plug
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-01-2006, 06:58 AM
