Results 1 to 12 of 12
Thread: Engine Fan doesnt turn off with the car
    VT exec
    Sep 2008
    Default Engine Fan doesnt turn off with the car
    hey guys today i came to turn off my vt commodore and the fan doesnt turn off with it. i have to remove the fan relay evertime i stop the car so my battery doesnt die. anyone have any ideas or anything that i should check? cheers
    VT exec
    Sep 2008
    vt executive
    May 2008
    dont remove the fan relay the reason its not turning off is because it cooling down it will shut off by itself when its ready
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If it doesn't turn off by itself after a few minutes then try replacing the relay, it could be stuck on.
    MY RIDE
    VT
    Aug 2009
    Had mine repaired earlier this week. Auto-electrician replaced the burnt out relay. Racq guy told me they only take the relay out if your a short distance from the repairer so the engine doesn't overheat.
    VT exec
    Sep 2008
    the thing is my fan didnt turn off after i turnd off my car it stayed on till the car battery died.. so yea i replaced the relay today. dont think it made a difference
    -Junior-'s Avatar
    -Junior- is offline <-- Back to Back in 2010
    vn auto
    Apr 2006
    S.W. Sydney
    Quote Originally Posted by fatboy15 View Post
    The relay was a common fault years ago along with the fuel pump relay, to a point that a rework was done. If you have replaced the relay already, was it a new one or swapped from elsewhere? Try another first and see how it goes.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    there are two relays.
    1/ for the temp
    2/ for the aircon
    nb: some models only use one.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    VT exec
    Sep 2008
    97 VT
    Mar 2012
    Newman
    Having this same problem with my vt put brand new relay in still doing it can anyone help me pls
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Mumzy89 View Post
    Did you replace the right relay? There are two, high speed and low speed.
    MY RIDE
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Did you get the relay from holden? As i was told that you can only get the right relays from holden, you can buy relays from other places but if you look at them there are two pins that are back to front from the holden ones.
    Which will cause the fans to stay on all the time. I went to 5 different places before trying holden an they all had the same realy which made the fan stay on all the time, put the holden one in an all fine.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
  1. why doesnt my thermo fan turn on when i press the a/c buttor vs calais
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2009, 08:32 AM
  2. Engine Number doesnt match rego please help
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2008, 10:07 PM
  3. engine wont turn over!
    By insane_1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2008, 01:32 AM
  4. Sluggish engine turn over
    By SLAF in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-10-2006, 10:54 PM
  5. engine just doesnt want to work.......
    By 9898989 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2006, 05:51 PM
