Results 1 to 8 of 8
Thread: Oil Filter Seal Leaks
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    Default Oil Filter Seal Leaks
    Hi guys,
    My VY S/C V6 seems to be leaking oil from the Oil Filter seal.
    At first I thought it was loose, so I tightened it. Was OK for a day or so and then it leaked again.
    Then I thought it was a faulty filter seal, so I replaced the Filter with a New One.
    Couple of days later, it leaked again. Tried Tightening, still same.
    Changed the oil and filter about a month later. After a few days, it leaks again.
    The Oil Filter Mating Surface on the car side is perfect, and the seals seem to be OK.
    I always put a smear of oil on the Filter seal before screwing it on.
    Could there be a problem with Oil Pressure. (Maybe too much).
    The car drives fine and there are no other oil leaks.
    Im a bit worried that something may happen down the track that I could have prevented.
    my baby
    May 2009
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    What brand of oil filter are you using?
    There was a problem recently with Ryco filters coming loose and leaking, maybe the store your buying yours from still have old stock.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Mar 2006
    Im using Valvoline Oil Filters. I havn't tried using another brand yet. The Seals on the Valvoline Filters seem OK. Quite Thick and Wide Rubber.
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    make sure rubber gasket from an old one isnt on there, if not it may actually be your rocker cover gaskets leaking and running down, mine does it constantly
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Is the oil actually coming from the filter seal? It maybe leaking from the oil pressure switch just in front and blowing back around the filter base!
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    I just replaced my oil pressure switch on my vs it was a mess didn`t know were it was leaking.
    It even looked like my power steering pump and rubber noses were leaking.
    So give it a degrease and check your power steering noses also.
    I buy holden filters and alwas replace the sump plug washer aswell they will leak if u kept using them and they are cheap.
    Good luck.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Those Ecotec pressure switches (and the L67 too presumably) have been known to leak - mine certainly did.
    As others have said, wash it all down so you can tell for sure where is coming from.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
  1. Oil filter seal blowing
    By mradam1986 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2009, 03:26 PM
  2. Rear main seal... Replaced but still leaks
    By VSteve in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-12-2008, 08:51 PM
  3. Help please!!!!! Auto filter seal!!!!!!!!!
    By cpbait in forum General Discussion
    Last Post: 07-10-2008, 11:02 PM
  4. Auto Trans: filter seal?
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-05-2008, 09:54 PM
  5. Front windscreen leaks water at the top seal
    By frustrated in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2006, 08:21 PM
