Results 1 to 6 of 6
Thread: bypass vx v6 bcm?
    ecotec v6 tf rodeo
    Aug 2009
    Default bypass vx v6 bcm?
    hi guys,
    i have put a vx v6 into a rodeo, and at the point where i am starting. i have spark etc and power to the injectors, but no pulse...
    from what i have read it is the bcm causing this, only problem is im not using one.
    so i was hoping there was away of tricking the ecu into thinking it is all ok?
    there were 3 wires that i couldnt find where they go so was thinking they may connect to the bcm, ill try and get my hands on a diagram and have a look through also.
    thanks very much
    brad
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The BCM controls the security so I'd say it is an immobilisor issue. Just hook up the BCM and it should all fire up.
    Visit my Facebook page
    ecotec v6 tf rodeo
    Aug 2009
    yeah, i only have the ecu and engine loom no other electricals.
    i read a few other posts that said "the auto elec just bypassed the bcm" etc, was hoping someone may now if its possible.
    had a quick chat to the local auto elec he said he heard a rumour about possibley oppening the ecu and disconnecting something... anyone else hear of this?
    thans brad
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    you'll be looking at either a BCM simulator, or a custom tune to disable the VATS (vehicle anti theft system)
    Mar 2008
    Mate try
    Pat gardner V6conversions , google v6conversions, he does a bcm simulater , hes in moree nsw,
    or marks adaptors will do them
    part gardner is cheaper
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    you will need the VATS turned off for it to run
    cheers GM
  1. bypass fan for my v6?
    By vn_v6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2009, 03:45 PM
  2. Bypass SRS
    By lil_mickey in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2009, 11:07 PM
  3. Bypass heater
    By spudd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2008, 07:27 PM
  4. Bypass Oil Filtration
    By bradcad in forum General
    Last Post: 15-02-2008, 03:28 PM
  5. bypass
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2004, 10:41 AM
