Hey alll
Iv got a power steering problem....
It makes a loud grown when turning and it is harder than normal to turn ...
Iv only owed the car 4 a little while so i have no clue wat it could be .... anyone had this problem or anyone know wat it could be.. It says the oil was changed on 50 000 its currently on 56 000 ..
Thanx in advance.......
check if there is any fluid left in the reserve; also check for leaks near the power steering pump. If you drive without fluid it will kill the pump.
Most likely its due to lack of fuel. If not the pump is on its way out!
Ok thanx heaps .....
umzz long shot, but maybe check your bearing plates? because i heard some springs may make the plates rub and turnging and that... well just incase all else fails give the bearings a go lol. good luck mate
