Results 1 to 8 of 8
Thread: disabling vats on vx ecotecs?
    ecotec v6 tf rodeo
    Aug 2009
    Default disabling vats on vx ecotecs?
    hey guys, doing a conversion with a vx v6 engine and using standard computer, was just wondering if it is possible to disable the vats on these ecus, (i hope it is...) and who can do it?
    when cranking the security light doesnt stop flashing is this normal or should it stop?
    thanks heaps guys
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The security light should not flash when cranking, the immobiliser is not turning off.
    MY RIDE
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    it is possible but its easier if you get a VT ecu as then you can just plug in a memcal with VATS disabled with the VX ecu its flash based and has no memcal so you need the whole ecu reflashed with a tune with vats turned off.
    ecotec v6 tf rodeo
    Aug 2009
    arggh, wish i new this before i started the engine conversion.
    does anyone know who can turn the vats off? i have a vx dash etc going in also.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    Quote Originally Posted by v6rodeo person View Post
    you can still run the VX dash and stuff off a VT ecu peice of cake its plug and play with the vx loom or doctorbob will be able to disable vats on the VX ecu im sure i know hes unsoldered a few chips out of them before his website is Rob's Creative Calibrations contact him through there.you will need the BCM for the VX as well to make the dash work i think too as all the comms go through the bcm for the dash if i remember right.
    ecotec v6 tf rodeo
    Aug 2009
    Quote Originally Posted by delcowizzid View Post
    ok now we are onto something, i have sent him an email, just gotta wait till i get the reply
    i have gone a bit backwards with the way i have done this conversion, i really should have bought a written off car rather than a host of parts.
    where i am at now is, i have a v6 auto engine loom and ecu from one car, i got a dash console bcm and loom and also ecu from another wrecker, put it together but still having the above mentioned problems with the vats. hoping disabling the vats will fix it.....
    thanks guys
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the ecu and BCM are linked you need matching ecu and bcm from the same car and need the key reader from round the ignition barrel and the keyhead as well that match the correct bcm or it will never go without vats disabled
    ecotec v6 tf rodeo
    Aug 2009
    i got the ecu from the car that i got the dash and bcm from, i got the igition barrel and key but the part that the little dick thing on the key contacts the barrel i havent got, ill go pester the wreckers again, hope they didnt discard it....
    thanks very much dude
    is the key reader as they call it in the workshop manual just a contact as it has only a one wire connection (the part that the protrusion of the key touches when in the ignition barrel)
  1. Disabling Supercharger
    By Slippy_Trippy in forum V6 Development And Modification
    Last Post: 20-08-2009, 10:54 PM
  2. de-tuning ECU on ecotecs
    By Jbird in forum V6 Development And Modification
    Last Post: 20-11-2008, 10:32 PM
  3. Vortech Superchargers on Ecotecs??
    By holdenkid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2008, 06:00 PM
  4. What Do The Ecotecs Put Out?
    By Pun in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2004, 10:37 PM
  5. Vats?
    By pheobe in forum Electrical Wiring / Questions
    Last Post: 16-02-2004, 06:24 PM
