Results 1 to 9 of 9
Thread: daughters vt running rough
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    Default daughters vt running rough
    my daughters vt runs rough sometimes. its had new plugs leads etc. someone said to get the computer reset. is this crud or for real. is its right does anybody know how to do it.
    should it go to an auto electrician with a pc to get it done.
    thanks.
    she is driving me nuts
    i do as the voices tell me
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    check the error codes from the computer yourself. The how to section explains how.
    Changed the filters lately ? fuel and air filters .
    To reset computer disconnect battery for an hour or so, then reconnect and start up.
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by greenacc View Post
    That's good advice.
    The fuel injectors could also be a problem. Buy a bottle of quality Injector cleaner (Nulon brand is quite good) which is designed to be added to the fuel. Add this to a full tank of fuel when re-fuelling. Unfortunately few people ever use injector cleaner but it is good preventative maintenance in my view.
    Occasionally run the car on a tank of premium. ( Yes I know it is expensive but I never use anything else in my commodore). The regular unleaded sold in Aust is quite poor. Do not use that ethanol blend fuel in your car.
    When were the spark plugs last checked and changed? If you do not know it would be worth putting in new ones. Make sure you use the type specified by GM for the engine and the plug gap needs to be correct before fitting.
    None of these things may solve the problem but , if the problem persists, obviously take the car to a good mechanic to trace the issue.
    VTvoodoo's Avatar
    VTvoodoo is offline 99 VT S2
    VT Executive S2
    May 2006
    Gold Coast
    in what way does it run rough? does it seem to just idle rough , or not smooth in acceleration? prob a long shot, but mine felt rough at idle, ended up being the engine mounts, the engine had sagged onto the cross member causing vibration
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    Bothered to clean the black crap out of the throttle body yet?
    Nulon Carby and Throttle body cleaner - try it.
    coasty's Avatar
    Feb 2008
    kanwal nsw
    cleaned the throttle body , ran injector cleaner and changed the plugs but still gets rough. mostly at idle.
    never used ethanol junk. still annoying me
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check the purge hose on the bottom of the throttle body. Make sure it isn't split and it is connected firmly.
    Visit my Facebook page
    VT ll S Pack
    Jun 2009
    all good advice, this never really seems to get brought up when it comes to rough idle and poor acceleration, yes leads and plugs all worth checking, but if all else fails, this could deffinitly b your situation, its wat was wrong with my vt s II, the rectangular piece of plastic that your coil packs sit on is called the DFI module, it pretty sure its wat what keeps everyhting runnign on time and perfectly, once i got this replaced she was perfect again, worth a shot, i just got my mechanic to check mine out, roughly $250 for a new one, hope this helps
    coasty's Avatar
    Feb 2008
    kanwal nsw
    ill try anything to get this thing fixed. im going nuts. thank for the idea.
    ill report back when (if) i find out
  1. vp running rough
    By fvdroadking in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-05-2009, 03:32 PM
  2. Vn - Rough start & Rough Running Below 2k
    By ghog1726 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 10:02 PM
  3. Need help with a rough running vn
    By gnomie1979 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2008, 10:54 AM
  4. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  5. running rough
    By Rumbl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2005, 05:24 PM
