I put a new set of Pacemaker extractors and a high flow cat yesterday and my car has been running really dodgy ever since. It seems to be choking on fuel and cuts out for a second as I accelerate. I thought I fixed it today when i took it back and they put on new ignition leads. But it is still ****ing up. Shouldn't my car be running better not worse?
Did you put your O2 sensors back in properly? Are they pluged back up? Are your spark plugs screwed in tight enough? Are all the bolts on the extractors done up tight? Did you use a silicone type material for your gaskets before putting on the extractors to make sure the seal is tight? (ie: gasket goop, grease, etc)
My bet at the moment would be to look into your O2 sensors. just make sure they are put in properly and are plugged in properly aswell.
Follow Your Dreams......RIP Brocky 1945 - 2006......May God Rest Your Soul
hey mate just had the same problem as you on saturday. Turns out when you take off the old headers it upsets the old engine parts a little bit and can crack the spark plug(s). Sounds like the exact same problem as mine so pretty confident just get some new plugs and all should be running swell. Got standard plugs for $5 each at repco. Hope that fixes it.
Azza
I got it fixed. Turns out that the exhaust centre that put it in stuffed a few things whilst putting it in. I took it to a mechanic and got a diagnostic done and it came up the following
Code:001
Low speed fan, No BMC Response
Code:002
Theft Deterrent Signal Missing
Code:003
Throttle Position Sensor Stuck
Read History DTC
No Trouble Code Information Stored!
O2 Sensor
RICH
LEAN
Power Balance
Average RPM During The Injector Cutoff
Injector 1 1007RPM
Injector 2 898RPM
Injector 3 899RPM
Injector 4 898RPM
Injector 5 894RPM
Injector 6 891RPM
When they did the extractors they also did the headlights and had to remove the battery to do it. And they think that might have done something to the computer.
did they fix it free of charge or u payed on top?
Yeah they paid for it. I had to take it to a mechanics to get the computer test done. The mechanic refused to make me pay for it and he billed them. Cause that mechanic had serviced my car only last week.
Sounds like you should go back to that mechanic more often.
Hard to find good ones these days.
Unfortunately I won't be going back to that mechanic as i'm moving to Wagga to start my career in the RAAF next month.
Then get friendly with the aircraft maintenance staff. If they can fix a 10 million parts aircraft I'm sure they can fix a car, LOL.
Ronald Reagan (1986)
hold your arse cheeks together... or spread em, watever. Join the army ya punts. Only worth it if your doing a trade.
P.S. 4 years of military service and id have to say the air force are the most jack, pathetic pack of f*ckin lying pieces of sh*t ive met. Never trust someone who says they fly solo.
Azza
