Results 1 to 4 of 4
Thread: VT Temperature Gauge
    VT Clubsport 5L
    Sep 2009
    Default VT Temperature Gauge
    Hi all
    I've had my VT clubsport with the Holden 5L for a few years now and it recently overheated and blew a head gasket. I've just spent the last 3 weekends removing the heads which I am going to deliver for reconditioning tomorrow.
    My question relates to the temperature gauge in the instrument panel - is this gauge run by the computer or is there a separate sensor for this gauge i.e. I know the ECT sensor screws into the front of the inlet manifold, but my limited understanding suggests there may be a separate sender/sensor unit for the instrument dash gauge. If there is, where is it located?
    I've looked at the wiring diagrams in the Haynes maunal but these haven't been any help.
    VP Exec
    Jun 2005
    You're not missing anything. The VT has only the one coolant temp. sensor, the output from which is used by the instrument cluster (via the BCM) and PCM computers. The earlier models did use separate sensors for the gauge and ECM/PCM.
    VT Clubsport 5L
    Sep 2009
    Thanks for the help. In that case I think I'll install one of those inline temp sensor adaptors so I can put an aftermarket temp gauge in for accurate real time temp data.
    YP Executive S2
    Jun 2009
    I have a VT engine in a vp commodore and cant get the temp gauge working is that because the vt temp wire has to run through the bcm
  1. Temperature gauge VN
    By hansron in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2008, 03:06 PM
  2. Temperature gauge
    By bboystyles in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2008, 11:15 AM
  3. temperature gauge
    By shonky12 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2008, 11:46 PM
  4. Temperature Gauge
    By VRsharkie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2007, 07:49 PM
  5. Vt Temperature Gauge
    By stephen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2006, 10:18 PM
