my vt air cond is stuck on the screen i cant here the hissing noise when i change the knob. is it just the switch or a bit more. as these run on vacum?
please help no-one has had this problem before?
i thought it was common.
remove switch panel you will probalbly find the plastic tag that holds the rotary switch in place has broken.
they are about 15 - 20 dollars from holden
problem solved it was just the vacum hose came off the rear of the manifold, now fitted with a zip tie. thanks for the mess, and pm's
