As the title suggests, anything break easy or are common for this type?
Also does the VX series have a engine DTC light like the VR`s do?, what does it look like?
oil pressure sensor/switch
piston slap
backlash in the diff but i think that might be fixed in the series 2
rear main seal leaks
What about the DTC engine fault light, plus is there anyway to read faults without software with this series paperclip work etc..
you need a tech 2 or some type of code reader to find fault codes
yes they do have a engine warning light
it is in the temp gauge
it is a pic of a engine with a lighting bolt through it
things i would look for is
*rear main seal leak and sump
*if auto slipping box
*in a manual clutch slip
*strut tops & caster bushes
cheers GM
