Results 1 to 6 of 6
Thread: Radiator or cracked cylinder head?
    VT Wagon
    Apr 2006
    Default Radiator or cracked cylinder head?
    G'day,
    Is there any way to tell if my car's overheating problems are due to a knackered radiator, or a cracked cylinder head?
    I've had one (trusted) mechanic tell me it's definitely a cylinder head, and basically told me to get rid of the car. But the dodgy pricks from my local Holden dealer have just told me I only need a new radiator. I have a bad feeling they are trying to get more cash out of me before fixing the real problem.
    Any help would be great.
    Cheers,
    LMac
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    Whats the Symptoms?
    When my radiator went it had a crack in the hot side (Drivers side) of the radiator. Caused the temperature to rise and fall while driving, the hot alarm would sound, then it would go down again. Replaced radiator and termostat, no problems after that. I would look at ur radiator before looking at heads.
    VT Wagon
    Apr 2006
    Quote Originally Posted by Hot-Rod View Post
    Whats the Symptoms?
    It has overheated a few times now, and is using a heap of coolant. The bottom of the radiator cap always has brown muck on it. The oil looks ok, not too milky or anything like that, but it's fairly new.
    The Holden guys I deal with are particularly shady, which is why I think they're taking me for ride!
    Ripcell's Avatar
    Ripcell is offline R8 FTW!!!
    324rwkw MY06 VZ R8 Maloo M6
    Apr 2006
    East Melbourne
    could be leaking from a number of places? does it leave drips after its been parked when its hot? could be inlet manifold gaskit also it its leaking from there the water might evaporite on the hot engine before it makes it to the ground
    take it to a different mechanic and get it pressure tested
    vn calais
    Aug 2009
    northern burbs
    Start car fill radiator! 1st
    if you get constant bubbles in the radiator with the cap of its the head! Simple
    VT Wagon
    Apr 2006
    Thanks for the responses - much appreciated. I've also noticed another sound recently when starting up - kinda sounds like water running down a pipe. Any ideas?
  1. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  2. Cracked Radiator
    By holden_chik in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-03-2008, 08:27 PM
  3. radiator cracked @ servo yesterday
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2007, 12:03 PM
  4. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  5. radiator cracked
    By S.T.S in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2005, 05:13 PM
