Results 1 to 2 of 2
Thread: Wheel Alignment
    VT Wagon
    Nov 2008
    Default Wheel Alignment
    Any wheel alignment experts here?
    A few months back I had all new tyres and a wheel alignment and balance done right after I put all new bushes in.
    Here are the results from that wheel alignment (only concerned about the front wheel alignment):
    BEFORE
    • Total Toe: +2.9mm
    • Half Toe: LH +0.9mm RH +2.00mm
    • Camber: LH -00°10' RH -00°32'
    • Caster: LH +08°12' RH +08°47'
    • King Pin Angle: LH +13°26 RH +13°19'
    • Included Angle: LH +13°16' RH +12°47'
    • Set Back: +00°05'
    AFTER
    • Total Toe: +2.0mm
    • Half Toe: LH +1.1mm RH +0.9mm
    • Camber: LH -00°16' RH -00°25'
    • Caster: LH +08°15' RH +08°46'
    • Included Angle: LH +13°10' RH +12°53'
    • Set Back: +00°02'
    Here are the results from the next wheel alignment done at a different store, about 7000km later:
    BEFORE
    • Total Toe: +6.9mm
    • Half Toe: LH +4.6mm RH +2.3mm
    • Camber: LH -00°20' RH -00°34'
    • Caster: LH +08°26' RH +08°31'
    • King Pin Angle: LH +13°52 RH +13°39'
    • Included Angle: LH +13°32' RH +13°07'
    • Set Back: +00°08'
    AFTER
    • Total Toe: +3.0mm
    • Half Toe: LH +1.5mm RH +1.5mm
    • Camber: LH -00°17' RH -00°32'
    • Caster: LH +08°32' RH +08°31'
    • Set Back: +00°09'
    In additon to this, I also got them to check the wheel balance with the existing weights on:
    LF: 15g - 20g
    RF: 0g - 10g
    LR 20g - 15g
    RR 0g - 10g
    What I would like to know is if that is normal for the wheel alignment and balance to be out that much 7000km later?
    vt acclaim gen 3
    Jul 2009
    vic
    do u drive on rough gravel or potholed roads, train tracks speed bumps etc...?
  1. Wheel Alignment
    By magg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2009, 01:29 PM
  2. Wheel Alignment?
    By CommVTS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-09-2009, 11:40 PM
  3. Wheel Alignment
    By VSTrev in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-10-2008, 08:28 PM
  4. Wheel Alignment
    By Shounak in forum General
    Last Post: 29-10-2006, 06:55 PM
