Hey guys recently my car has been flashing HOT on the little lcd screen and the temp needle jumps straight up. about 10 seconds at idle and the needle will move down a little bit.
Then as i take off the temp goes back down to normal. This happens on and off every now and then, last week added more coolant and engine oil and also a new air filter and it worked great for 2 weeks now its just started again any ideas of what this could be i really dont wanna be spending big money when the mechanic starts charging me all over the shop
Cheers guys
Anyone????
Are there any coolant leaks? Check under your car while there's pressure in the system (while hot). Has any one done anything to the cooling system that may have let air in?
I would be looking at the thermostat first, it could be sticking in the closed position till the coolant overheats, then suddenly opening, bringing the temp back to normal.
Perhaps the temperature sender, located on the side of the thermostat housing or its connector, is at fault.
What usually happens is the coolant level drops a little so that the sender unit is actually not completely covered by coolant. Steam is hotter than coolant, so the gauge will read high when idling, then as the revs build up, the sensor gets covered by the flowing coolant and the gauge drops.
You will most likely have a small leak somewhere. The most common place is the inlet manifold gasket on the ecotec. Also check the water pump, all the hoses and make sure the cap is OK. If your expansion tank empties, it could be the cap.
check your cooling system for leaks and make sure the air is bled properly.
less timing.... more boost!
Found a small leak coming from just in front of the CAT it drip drip drippin any ideas od what is actually leaking
That is most likely just your air con drain tube.
hey guys just got quoted 215 to fix leaking heater tap is this about right or what
might be welch plug, thats what im getting replaced tomorrow.
or around the rear main there is a seal where you gottta remove the transmittion to fix
$215 !!! what a ript yourself from repco $20-30 and its a simple part to fit , do a quick search , itll save you heaps , half hour job
I wouldnt be paying 215 its a Piss easy job do it yourself
done my heater tap myself, easy job, make sure you have coolant to top up, but its easy job
is it the heater tap leaking? or is a hose that is leaking going to the heater tap? i had a leaking hose but got recommended to replace the heater tap as well as 9 times out of 10 it will break due to it is very brittle.. I managed to replace the hose without breaking it and it hasn't leaked ever since, $215 is way over priced your better off doing it yourself its not hard at all
