Results 1 to 12 of 12
Thread: steam and bad smell from air vents in vt series 1
    vt executive s1
    Sep 2009
    Default steam and bad smell from air vents in vt series 1
    hi i have a vt exective series 1 and i have steam coming from the air vents,when you use the heater it has a bad burning smell,air con still works fine
    any ideas and how to fix
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    There is a good chance that the heater core is leaking.
    MY RIDE
    vx supercharged
    Feb 2009
    could be your drainage from the evaporator is blocked and water is building up
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    Jun 2004
    So far I haven't found a thread that tells me how to get to the heater core? My Statesman has a leak and its bl***y cold with it disconnected! Instructions and piccies or linky would be helpful, please. Just found it, here Anything special for those with airbags?
    Last edited by Olden; 14-10-2009 at 01:00 AM. Reason: Found what I was looking for
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    Heater core is a huge pain to replace.
    I just got a bottle of Bars Leak and put it in, no heater core leak since
    vt ss commodore
    Sep 2009
    Quote Originally Posted by holdenvtece View Post
    get some chemi weld and use it bloody heater cores
    vt ss commodore
    Sep 2009
    Default jammo 64
    my vt ss is losing quite a lot of coolant ,but no leaks. heater core not leaking. could it be dodgy radiator cap
    VTS5's Avatar
    VTS5 is online now TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by jammo64 View Post
    Or cracked heads :-))
    vt ss commodore
    Sep 2009
    Angry vt aircon mystery
    i have a vt commodore when you accelerate the aircon changes vents and blows through the demisters. when i back off the revs it returns to blowing cool air out the dash vents . i dont understand this and it is giving me the shits
    GOTMYN's Avatar
    GOTMYN is offline Stab it and Steer...
    Whippled 5.7, VE SV6, GU Patrol 3.0DI
    Sep 2006
    Mornington, Vic
    Mine has a distinct smell of coolant when the heater is on, and it will fog the windscreen for the first minute or so... I was told it is a bypass valve at the core, and it normal on VT's.... It will not loose enough fluid to worry you, so put up with the smell, or pay $500+ to get it fixed......
    If your getting steam, I'd say it more like the core though....
    If I'm not pulling Toyota's out of the Bush, I'm pulling 12's in the Sig :-)
    VT Berlina Wagon S1
    Oct 2008
    Sounds like the mouse from the ECU (Engine Computer Unit) has crawled into the AC ducting and died... a common problem on these earlier models, because the car/mouse is now eleven years older or more (extremely old for a mouse). An ECU diagnostic will tell you if the mouse is not active any more, just get a new one. If you're handy with a soldering iron you can re-wire a PC mouse to do the job. The smell will go away after a while... just like a dead mouse in the ceiling of a house etc.
  1. steam coming though the vents
    By MR__CALAIS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2009, 07:35 PM
  2. Smell coolant through air vents?
    By social in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2009, 10:58 PM
  3. Steam/SMOKE?!? Air vents.. VT
    By Christina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-12-2006, 03:31 PM
  4. VT Steam from Vents
    By beyuch in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-06-2006, 07:40 PM
  5. Fuel smell through air vents
    By nevrl8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2004, 09:14 AM
