Results 1 to 10 of 10
Thread: L67 Head and Charger on L36???
    s1 vt
    Jul 2005
    Default L67 Head and Charger on L36???
    Hey guys ive got a rebuilt 4.2 l36 @ 8.5.1 compression ration and was wondering if i wack on the L67 heads and charger will it all work with a 5spd loom and plugs? i dont need to worry about the ecu as i have a Current wired up Aftermarket system.
    VS l67 statesman
    Dec 2008
    the bottom end will be your main concern it wont hold up to the boost like the l67 bottom end
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I'm guessing the OP has a stroker kit judging how he has a 4.2L engine. If they are good forged parts then yes it will hold together nicely. But you will need a L67 loom. I'm guessing you have already upgraded the fuel system, because L67 use bigger injectors, but if they come with the heads then thats not a issue. I'm sure theres other stuff you need, but it shouldn't be hard.
    Ronald Reagan (1986)
    s1 vt
    Jul 2005
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    not a lot l67 runs slow and fast fuel pump adds 2 extra wires not nessacary though runs fine on the stick ecotec pump wiring anyway.and theres a boost control solinoid which isnt that nessecary either but would be easy enough to add
    VX Berlina
    Apr 2007
    Sounds like an easy choice to me. L67 all the way!
    VY SII HBD Calais L67
    Dec 2006
    You don't need an L67 loom afaik. You can run a single speed fuel pump and the only other engine bay loom difference I can think of would be for the boost bypass solenoid on rear of the passenger side head.
    My opinion, go turbo into your ecotec plenum. It will cost about the same as an M90/ L67 top swap but the heads are physically the same between ecotec and L67, the only difference been the injector port locations.
    If you have a N/A cam it will be more suited to turbo anyway and you can get more lift on the intake by increasing the rocker ratio to help the turbo a little.
    VYII Calais L67
    s1 vt
    Jul 2005
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    I think L67 Injectors are located in the head, whereas the ecotec ones are mounted in the manifold, also you would maybe want to change the cam to a L67 one, im sure they must be different.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    Dec 2006
    Quote Originally Posted by ScoHar View Post
    L67 and Ecotec share the same cam. The L67 is advanced 2 degrees is all
    VYII Calais L67
  1. [Ecotec] on off charger.
    By orthaeeoul in forum V6 Development And Modification
    Last Post: 30-04-2009, 09:07 PM
  2. crs charger
    By daron in forum General
    Last Post: 02-02-2007, 10:46 PM
  3. vs charger pod
    By danny1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2006, 11:29 PM
