Results 1 to 4 of 4
Thread: Speedo back light / shifter lights not working?
    1993 VR Executive Commodore
    Oct 2008
    Default Speedo back light / shifter lights not working?
    Hey guys, just went for a drive in the dark so havn't checked any fuses or anything, but usually when i turn my headlights on, i get the green lights on my dash behind speedo and lights on my auto shifter.. lights on both of them not working but headlights still work??
    could it be a blown fuse?? any ideas guys? thanks
    VT
    Dec 2008
    well I think you need to check the fuse box under the steering wheel, the diagram on the plastic cover in front of the fuse box will help you to find the right fuse to check , you should look for somthing like instruments / cluster ilumination .... if everything is ok with the fuses maybe you have burned lights at the gear shifter and the instrument clister.
    Attached Thumbnails Attached Thumbnails Speedo back light / shifter lights not working?-cabin_fuse_panel.jpg
    Oct 2008
    cheers mate ill have a look tomorow mornign in the daylight! thanks heaps
    Oct 2008
    hey mate, "instruments / cluster ilumination" fuse was burnt out... so i replaced it with another 7.5 fuse... this fixed it.. then when i was driving lights went out again... checked fuse and new fuse had burnt out?? any ideas?
  1. VR - Light on Speedo Arrow not working
    By CrimsonThunder in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2008, 06:33 AM
  2. Reverse light not working on Monaro tail lights
    By TOD.000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2008, 08:56 PM
  3. Lights for the rear demist. and int. light buttons not working
    By 1vngal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2007, 09:38 AM
  4. How do i fix my HUD/Speedo/Auto gear shifter lights?
    By ShIbBy_industries in forum Electrical Wiring / Questions
    Last Post: 19-07-2006, 11:07 AM
  5. No Parkers, Speed Alert, dash lights or shifter lights.. Help..??
    By Grommitt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2006, 10:36 AM
