hello. i have just gotten my VT Executive 98 and when i turn corners it makes clunking noises. it doesn't sound healthy. can someone help me find my problem
Is it from the front of the car or the back?
Could be Swaybar Droplinks, Rack, Diff, CV's...etc etc
I have the same problem.
I had a safety check on mine a while ago and they said the ball joint needed an adjustment.
They said its not urgent to fix it if it doesnt get worse and mine hasn't.
But yeah could be that.
guys, i had this problem, is your car lowered?
if you have vr or other model springs in your vt, sometimes the strut rubs and causes a weird noise when you lock the wheel. best bet if you do have non VT springs, is to get new springs, and see if barings need replacing. hope this helps.
