Results 1 to 6 of 6
Thread: Nolathane 48166 Adjustment
    VT Wagon
    Nov 2008
    Default Nolathane 48166 Adjustment
    help!
    I fitted the Nolathane 48166 Radius bushes a while back and set them both to +1 deg
    I got a wheel alignment the other day and these were the results for the caster.
    Caster: LH +08°32' RH +08°31'
    They said I need to take a degree off the drivers side and bring it back for another alignment.
    Problem is I've lost the instructions. I found this post How To Replace Radius Rod Bushes VT / VZ but I know that's not correct because mine goes 4mm 8mm Flat Bush Flat 2mm and that's +1 degree not standard.
    Does anyone have the instructions around still?
    I'm really desperate, need to get the car in at 8am tomorrow morning for the alignment.
    VT Wagon
    Nov 2008
    Figured it out, +1 example was wrong. Should be like this:
    -1/4 deg Caster Setting
    (A) (B) (C) (D) BUSH (D)
    +1 deg Caster Setting
    (C) (D) BUSH (D) (A) (B)
    +1/2 deg Caster Setting
    (B) (D) BUSH (D) (A) (C)
    STD Replacement Setting
    (A) (B) (D) BUSH (D) (C)
    FRONT OF CAR -->
    (A)=8mm spacer (B)=4mm spacer (C)=2mm spacer (D)=Flat Washer
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    excellent post from yourself hehe, i have just moved and racking my brain as to where i would have put the instructions.
    VT Wagon
    Nov 2008
    Acutally it turns out they are wrong too and I ended up with minus ¼ degree.
    Got hold of an original copy of the instructions and will post here soon. Until then, nobody follow these instructions!
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    Jul 2006
    Are those correct, are the minuses and pluses in the right spot ? And which way is front of car. When i find them i will scan and post unless someone has the exact.
  1. Nolathane bush kit - VN
    By Post Vintage in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2009, 03:01 AM
  2. [VIC] F/S Nolathane VT-VZ Castor rod bushes. New. #48166
    By chargedvx6 in forum Parts And Other Items For Sale
    Last Post: 24-02-2009, 09:59 PM
  3. Nolathane gear
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-01-2007, 01:10 PM
  4. nolathane kits
    By statement in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2005, 10:31 PM
  5. nolathane bush kit??
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2005, 12:19 AM
