hey, did a quick search, nothin came up, just wondering how to get pads back into a vx. cheers guys
if you can, get some line clamps and clamp the rubber hose going to the caliper and release the bleeder screw and either lever or use a g clamp to push the piston back in
you can do it without clamping the line but pushing the sh*t fluid from the bottom of the lines can scr*w your abs modual
DO NOT clamp the brake line's.
simply push the pistons back.
my method:
with the old pads in the caliper, use two large screw drivers or shifter handles.
and criss/cross for leverage to push the pistons back symiltaniusly.
(you will damage the old pads)
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
cheers guys, got donethanks allot.
