Results 1 to 4 of 4
Thread: Would a screwed key allow crank then shut off?
    98 vt commodore
    Dec 2008
    Default Would a screwed key allow crank then shut off?
    I'm having issues starting my arbjust wondering if a screwed key would allow you to crank the car but shut off straight after it cranks
    VT BERLINA, TOYOTA HILUX, NISSAN NAVARA
    Sep 2005
    Yes, this happened to me a few months ago. Car would crank a little then nothing with the key still in the start posi. Just started using my spare key and don't have any trouble with it. The immobiliser could also be at fault in the sense that the key isn't talking to it, so when it happens again just lock and unlock the car and try because that seems to also work.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Sometimes the little sticky outy bit on the key doesn't make contact with the 2 tabs on the ignition barrel when you insert the key. You can use a small screwdriver to CAREFULLY bend them out a bit , you only need to bend them out a fraction .
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    Your key fob is flat.
    Replace and recode and your car will start.
    Had this happen in the VT last year
  1. Is my DFI screwed?
    By dazza 38 in forum Electrical Wiring / Questions
    Last Post: 30-06-2009, 07:07 PM
  2. VT A/C Fan won't shut off
    By oliviabreed in forum Electrical Wiring / Questions
    Last Post: 24-02-2007, 09:00 PM
  3. Screwed Crank Thread
    By Meerkat in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-12-2006, 12:25 AM
  4. my tappits wont shut up in my vs berlina deos anyone now how to shut them up???
    By lestat21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2006, 09:08 AM
  5. should shut the %#$@ up
    By chevy_big_block_bro in forum General
    Last Post: 12-09-2005, 07:21 PM
