Results 1 to 3 of 3
Thread: vt alternator issue
    VT SS 5.0ltr
    Apr 2007
    Default vt alternator issue
    hi all
    I have a 5.0 VT the I am getting no charge from the alternator unless I wiggle the plug at the rear with 2 small wires coming from it. I checked the main feed wire and it was all good.
    I can start the car and the "battery" light will be on, I pop the bonnet and give the plug a wriggle and the alternator fires up and the light goes out by the time I hope back in the car.
    My question
    Is it just a short within the plastic plug or is it a regulator problem that is fixing itself when I wriggle the plug.
    I have looked around on here but havent really found anything definitive.
    thanks everone
    Mar 2008
    Mate could be a bit of corossion on the terminals, remove the plug and see if the terminals have a white powdery residue on them, if they do give them a light sand with a bit of fine sand paper
    If they are clean could be a broken wire in the plug, i dont think it would be the regulator as it would play up all the time
    VT SS 5.0ltr
    Apr 2007
    is there a way of testing the regulator ?
    also one of the brushes looks pretty knackered, how much wear is normal?
    thanks again mate. I cut the wires off the plug and put other crimped things on and the problem is still there.
    Do you know where I could get a new plug?
  1. Alternator issue
    By And_ROOS in forum Electrical Wiring / Questions
    Last Post: 13-03-2009, 07:04 AM
  2. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  3. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  4. v8 alternator issue
    By Jazack in forum Electrical Wiring / Questions
    Last Post: 06-01-2008, 07:22 AM
  5. VS alternator
    By CANYONERO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2006, 07:32 AM
