Results 1 to 3 of 3
Thread: VT V6 rattle noise
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    Default VT V6 rattle noise
    my engine will make a bad rattle noise between 1800 and 2200 revs under light load/acceleration like a buggered cat.
    using a stethoscope i listened to the extractor on the RH side and its a nice quiet pur however on the LH side its a rattley noise.. removed the LH tappet cover to check springs and rockers and they seem to be fine...
    enigne just clicked over 240,000 so its a bit worn
    VT Commodore wagon series 2
    Nov 2008
    Outer S/E Vic
    Use your stethoscope to check front idle pulley underneath alternator, they can also rattle & resonate through the motor.
    Also check front balancer for damage.
    VT EXEC
    Mar 2006
    I have a similar problem as well, but presents it self as a loud squeak. Replaced the drive belt, squeak was still there, but not as loud. It also goes away after about 15min when it warms up. I cant seem to find the source of the squeak, is it worth replace the tension pulley's or are there any other things i can look at that may bee the problem.
    Vt exec 98
    230000kms
  1. Loud rattle noise from motor
    By Azp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-12-2011, 02:07 PM
  2. Rattle noise coming from cats
    By OBR1EN in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-12-2008, 01:36 PM
  3. VP Rattle noise in Engine
    By Trentasaurus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-12-2005, 02:32 PM
  4. Rattle Noise
    By PuNkuS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2005, 06:25 PM
  5. rattle noise
    By V6VL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2005, 02:27 PM
