Results 1 to 18 of 18
Thread: VT Engine Number
    pprkut is offline Banned
    vt calais
    Sep 2009
    Default VT Engine Number
    hey, I've already searched and can't seem to find much on where the engine number is on a VT V6 ecotec engine, can anyone shed some light on this?
    much appreciated
    Vt Berlina 1998 Not my dp
    Jun 2009
    Frankston
    should be on the front of the engine below the coil pack. you will need to remove the cai to get a good look and a torch
    Quote Originally Posted by Cobez View Post
    You sir, are as gay as aids and as camp as a row of tents. You also fail..
    vt calais
    Sep 2009
    Quote Originally Posted by Fitzy09 View Post
    can I get some more info on where it is exactly?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    This may help
    and 3 Dangerous non ABS VN's
    vt calais
    Sep 2009
    Quote Originally Posted by 88GreenVN View Post
    This may help
    already seen that pic, doesn't really look like my engine tbh, maybe i'm just looking at it wrong
    Vt Executive
    Jul 2009
    open the bonnet and take off the cai right in front of you. after this is taken off just look right in front of you with a torch and should be roughly parallel with the cai bottom that u took out. very hard to see all the numbers, might need a screw driver or cloth to wipe the numbers to see better. hope this helps
    Jun 2009
    Frankston
    This should help????
    vt calais
    Sep 2009
    yes that helps a lot, i'll check it out today and let you know how I go, thank you!
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by pprkut View Post
    How is it not like your engine? The engine number will still be in the same place.
    When clean of grime/oil use a bit a white chalk to make the number stand out.
    ducker85's Avatar
    ducker85 is offline Calais man
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    that's the same image holden gave me ans it didn't help on my L67 at all it's just a hundred n 1 pulley in there
    ducker85's Avatar
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    88GreenVN's Avatar
    Jun 2006
    for a VT S/C engine - same place as all the VT's behinde the water pump outlet directly under the head. Front side of the block
    ducker85's Avatar
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    so do I need to pull anything off the motor??
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by ducker85 View Post
    Probably the coils and DFI unit may need to go. Have a bit of chalk ready too just in case you find it and want to read the numbers.
  15. #15
    ducker85's Avatar
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    i have to do the SA police check and show thw cops my number, so i hoping i didn't have to pull it apart in there driveway (country SA) I might just take it to Adelaide police n might be eaiesr
  16. #16
    88GreenVN's Avatar
    Jun 2006
    A mechanic may be able to get the engine number while on a hoist. Or put the car on stands and get a good spot light and chalk. Digital camera may be a good help too.
  17. #17
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    I'm assuming they make it hard to get to so it is even harder to tamper with?
  18. #18
    ducker85's Avatar
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    Quote Originally Posted by jazza15 View Post
    Nah it's just so you have to pay holden to find it.
    I found it tho!
    I got the tourch on it after a quick de-grease and coloured it with calk for the coppers
  1. Alloytec Engine - Where is the engine number?
    By Acrow in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2008, 02:33 PM
  2. VR Engine number
    By tittezzzvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2008, 09:06 AM
  3. vt engine number
    By vtsteve in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-07-2008, 10:32 PM
  4. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  5. Where is the engine number?
    By ascension24 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2006, 11:18 PM
