Results 1 to 4 of 4
Thread: Hesitation on start up? Running out of ideas
    SSZ 5.7LTR & 01 VX V6 Supercharged
    Aug 2009
    Toowoomba
    Default Hesitation on start up? Running out of ideas
    Ok, so I have a fresh recond super 6, 20 thou over,injectors sonic cleaned,manifold machined due to heat stress warpage, leads are only 3 months old before I blew up the last engine, just put new NGK plugs in, took out performance memcal and installed original.......But it still takes at least 4 seconds on the key to start it, what am I missing? new coil pack? new fuel pump?
    My other engine would kick over straight away . Im truely stumped.
    Aug 2009
    Toowoomba
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    Could be alot of things that could cause hard to start eg fuel pump leaning out, not holding pressure (so you will need a fuel pressure gauge to see if it holds pressure, leaking injectors??? just cuz they have been reco doesn't mean they are ok. But way to test them start the car up, turn it off, then disconnect all the injector plugs wait a few hours or over night, then start the car the car up with the diconnect injector plugs, if it starts then your injectors are leaking. Another thing could be a coolant temp sender, if it is faulty if will be giving then ecu wrong signals eg TOO COLD and the injectors will be fully open and pouring in the fuel. Hope it helps
    NEVER LATE IN A 355ci
    Aug 2009
    Toowoomba
    Quote Originally Posted by BT1-355 View Post
    Thanks mate, I will give it a try this weekend. At least you've given me another possible scenario.
    cheers,
  1. any ideas? she wont start
    By jmsbaum in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-08-2009, 09:30 AM
  2. wont start, ideas?
    By vn calais manual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2009, 01:12 AM
  3. Another fuel econ question, im running out of ideas?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2008, 05:12 PM
  4. running rough at start up
    By starfire vc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 06:09 PM
  5. VH 253 dual fuel running VERY poorly..ideas?
    By Rzeractor in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-04-2007, 10:02 PM
