Was going to get a few back end rubbers done on friday as I went into pedders and asked what can coz it too shake/shudder under load. I tought some sorta rubber mount like diff one or the 1 on each side of the cradle.... Got board and jacked it up b4 and seen that the rubber that is in the middle of the tail shaft and diff is all torn and looks to be very wasted.... So rang them back up and asked could it be that an he said yes for sure.. So I have it booked in and he will have a look at it for me too be sure b4 going ahead with the work needed.
Anyone know how much these rubbers would cost.... Was going to cost me $320 too get the others done but Its not them now so I'm alittle happer hahahaha.... I think he called it the cupling ? or something too that affect ..
Always In Construction Mode!!!!!![]()
Well it seems to be my rear coupling rubber... and have a list of other little things but he said fix that 1st as its pretty shot. $ My Q is is it worth $645 fitted... I rang holden and for the part itself with new bolts is $190 and fitting I can do myself... that will save me some $ there an then get a few other things fixed with what im saven in $ ?
Good too see alot of info......
On another note. What the hell are the 3 bolts that hold it. The other 3 are normal but theres 3 more that have the weird head on them. ?
maby torx bolts
Yeh thats them lol, Could'nt think of the name, All good gunna get some tonight and give it a crack tomorrow. And one know if its a hard job. besides undoing the 6 bolts ? does the tail shaft just drop out or do I need to do more. All I remeber when I done the rear end change in my mates car is the tail shaft just poped out when we pulled the whole cradle out ?
its easy but youll need some torx sockets i got a set of impact ones at work apprantly no one makes them mine are action
sp has a good set (non impact) i think autopro sells them
