Results 1 to 8 of 8
Thread: oil pump or lifters??
    VT Berlina S2
    Dec 2004
    Default oil pump or lifters??
    Hey All,
    been getting some crazy tappet noises happening when the engine is cold, and as each day passes, its taking longer and longer for the noise to go away.
    i just did an oil and oil filter change incase it was the filter causing issues, but its the same.
    so i thought i would open the oil cap to see whats going on while the tapping and noticed that there was no oil around the tappets etc.
    im thinking its either the oil pump not working properly, but when i start the car, the oil light doesnt stay illuminated.
    if it IS the oil pump, should the oil light stay on? is that what indicates an oil pump issue?
    could it be something up top preventing the oil from moving up?? hydrolic lifers??
    2005 vz sv6
    Aug 2009
    Australia
    has been about 3 threads like this in the past two weeks.
    Either tappets or lifters, both are expensive to fix.
    I had the same issue with my 99 VT, used a lighter synthetic oil and have had no issue since. (been about a week and a half) Think a lot of other people tried that with no success though.
    VT Berlina S2
    Dec 2004
    So far im not getting tappet noises anymore.
    I used an engine flush and had to run it in idle for 20min before the noise disappeared (saturday morning) and i left it in the system until Monday morning, drove all over the place and not one tap, in fact sitting at the lights, it was so that smooth that i thought the car wasn't even running. I replaced the oil and filter on Monday morning and all is good so far.(fingers crossed)
    Seems like i had a blocked somewhere, oil pickup perhaps?? who knows.
    VT SS 5.7
    Sep 2009
    Kuwait
    I have vt 5.7 and I have the same problem, tried to flush it as the official dealer recommended and it didn't fix it, then they told me that I need to replace the oil pump. Since I will replace it and the original oil pump has faults I thought to get something different, unfortunately I was trying to get some info on a better oil pump here but no has replied, but I looked around and found melling, they have oil pumps for LS1 engines, some are high volume oil pumps. and now I just need to know which one one would be the right one for me.
    hope that info helped.
    carless for now
    Feb 2007
    perth,Western Australia
    for a ls1 the lifters are shit and will always make noise especially the vt ls1's
    VY SII HBD Calais L67
    Dec 2006
    Lifters for the LS1 and ecotecs are the same.
    Try lifter free up with fresh oil as a starting point and if that fails to fix the issue you will need more desperate measures.
    BTW, how many kms on the car, what oil are you running and is the car on petrol only or LPG as well?
    VYII Calais L67
    VZ Maloo. 6 Speed. OTR. Tune. Some other bitz
    Jul 2010
    Yeah my Gen3 is a bit noisy like this? lifters!!? it sux a bit when your cars dun up and you do want ppl to look. a loud stereo and a loud exh usually fixes this when ppl look ahha.. anywho i quietend mine down quite a lot by using a good oil and mixing 1ltr of Lucas oil stabilizer in it.. still a lil noisy now and then but you get that,.. cant fix everything hey.
    Outta interest whats the cost of lifters supplyed and fitted?
    Dec 2006
    Quote Originally Posted by SSINZ View Post
    Try 20-60w full synthetic oil. Works for most with the gennas
    VYII Calais L67
  1. Lifters
    By nicktarana in forum General
    Last Post: 08-07-2009, 09:16 PM
  2. VP lifters
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2009, 05:43 PM
  3. Lifters
    By DavoVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2008, 06:17 PM
  4. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  5. Lifters
    By brad_m_is in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2006, 08:08 PM
