Results 1 to 21 of 21
Thread: How Do i Change The Coolant
    V6 VT Commodore
    Aug 2009
    Tamworth, NSW
    Default How Do i Change The Coolant
    Well its been 30,000 since i baught the commodore and i wanna change the coolant... but how? haha
    where is the drain plug...if they have one?
    there was another thread exactly the same in the VZ section i asked there and they didn't even help they just told me to come here and start the same thread....snobbing pricks just cause they own newer car then me
    so yeah...how?
    2005 vz sv6
    Aug 2009
    Australia
    I think perhaps because a question of this nature is so easily solved with typing it into google.
    V6 VT Commodore
    Aug 2009
    Tamworth, NSW
    yea but thats gay plus there are always tips that people with experience will know that google will never know thats why i ask for tips on here mate, anyone can go to google and find out what they gotta do... besides thats just un-social going onto google lol
    DVS's Avatar
    DVS
    DVS is offline D̮̯͓͂͌ͤͬ̌ͣ̈ͧͩ̃͐ͩ͛̔̀͛̑ͯ ͎̞̜
    VT V6
    JigSaw Puzzle Monkey Champion!
    Jun 2004
    Quote Originally Posted by MY-42-VT View Post
    so yeah...how?
    This guide will help you out How To Flush A V6 Cooling System
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Drop the bottom radiator hose, let it drain out. Take the most front heater hose off the water pump (make sure heater is turned to full, car still off) connect a garden hose and blast it, until it flows clear. Leave the hose off.
    Remove the engine cover thingo, and at the thermostat housing undo your bleeder valve.
    Use an old radiator hose to seal the radiator but act as a funnel (so the highest air point is now your radiator), start filling with genuine coolant, until it comes out the heater hose, fit the heater hose, this just helps get out alot more air. Keep filling until you get a consistent flow out the blleder valve then nip that up.
    Run car with rad cap off, and let it get to temperate and fill as required.
    You can use compressed air to get the remaining water/coolant out of the block before filling it up if you feel its neccasary.
    Also you can fit the radiator hose before starting to fill, I just do it this way for less chance of air getting in the system.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Bugger theres a work guide, I didnt need to type all that :P
    V6 VT Commodore
    Aug 2009
    Tamworth, NSW
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    To drop it all you need to take off the knock sensors behind the sump, but no need. Just fill and flush untill clear. When filling, disconnect the hose from the thermostat housing and fill into that hose, that way the whole radiator and block gets filled up and water will trickle out from the housing as there is a little hole next to the thermostat, when it runs out of the housing, out the hose back on. Then run till a lil warm and open the screw on top of the housing and bleed it a few times for a week. If the system is properly sealed when you bleed it it will suck water from the reservoir, so top up in there but dont over fill it as it counter balances and throws out water from the overflow. SMall top ups from the radiator filler but try to use the radiator filler as least as possible to keep the air out.
    Also if changing the thermostat, go for a high flow thermo (Tridon have them) with the original factory setting. It does the same thing as a cooler one, but still runs in sync with the radiator fans and ECU.
    executive vt 5.0lt
    Feb 2005
    west suburbs
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    If your removing the knock sensors to drain coolant theres no point. Its next to impossible to remove without a hoist and isnt worth it for the extra litre you get out if that. You would be better to spray compressed air down and try and blow the rest of it out, alot easier.
    Jul 2006
    Quote Originally Posted by Tom_1569 View Post
    You get more like 6 litres out. Ever wondered why when you drop the bottom hose and fill up, only 5 litres goes back in ? Its a 12 litre system, there is heaps left in, flushing with a hose dilutes it to near pure. Knock sensors are behind the sump, the part where the sump bulges out.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by vxcalais_01 View Post
    I've always got 9.5-10 Litres back in, or about 10.5-11 blowing with the compressor.
    I never bothered to remove the Knock sensors as the holden mechanic down here told me theres no point, and they dont even do it.
    Jul 2006
    Cools, good advice then. So you just blow it in from the housing ? Holden worksop manuals and gregories show removal of knock sensors to remove all coolant. All the sediment comes with it as well.
    Sep 2004
    the way i flush my coolant is i take waterpump hose off i then put a garden hose in radiator then start my car running all the water flushes thru the waterpump and cleans radiator and inside engine its the most practical and easiest way to do this method, then take cover off and bleed the screw!
  15. #15
    vt berlina series 1
    Sep 2008
    easiest way is to remove one of the heater hoses from the block shove the hose down it , (make sure heater is turned on beforehand) aqnd run hose , take your bottom hose off as well then hold your hand over the end of it to flush it back thru the heater pipe end as well , takes 5 minutes
  16. #16
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    The front heater hose (it could be the back) off the water pump, and just make a seal with one hand and blow down it with the compressor, water will come out the bottom radiator hose. Good point about the knock sensors removing sludge/crap though. I wouold say if it hasnt been done in a while then it wouldnt be a bad thing to remove the knock sensors.
  17. #17
    dynoryder is offline Banned
    vp executive wagon
    Oct 2009
    A.C.T.
    lol manuals lol
  18. #18
    Jul 2006
  19. #19
    vp executive wagon
    Oct 2009
    A.C.T.
    i take it your a mech i am mech and i hardly use manuals i try to understand the car in my mind and do stuff as fast as possible which im good at my shop turns over a lot more then any one else in my area my turnover alone (about 1/6 of the shops) is more than k-mart tyre an auto for a month
    so i make the same money as a hole shop the guy i work with doubles me but he sells a lot of parts
    so i pump out the cars learn stuff and take it all in but i dont ****around reading bullshit half the day
    the only time i read manuals is when im stuck and dont know how to do something that raerly happens
    p.s im sick today thats why im on here at this time of day
  20. #20
    VS Exec Series II
    Mar 2005
  21. #21
    VS Exec Series II
    Mar 2005
    double post
  1. Coolant change
    By dans_vz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-08-2010, 07:22 PM
  2. SS coolant change
    By Holden V8 SS Ute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-01-2009, 03:21 AM
  3. coolant change.
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2007, 04:32 PM
  4. Coolant Change
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2005, 09:39 AM
  5. Coolant Change
    By DJ Majah in forum General
    Last Post: 29-04-2004, 11:22 PM
