Hey guys need urgent help
My 97 vt door will not close. Where the lock meets the body that mechanism seems to be locked in position and all the plastic and the spring seems to all be broken how much is it for a new mechanism and is it easy to fix?
Use a screw dirver to put the door mechanism back into the right place then id look at the striker on the inside of the door.Ive had to fix a VT with this problem.All it need was to be moved a bit and door was sweet again.
