Results 1 to 18 of 18
Thread: Handbrake question
    Supercharged VX S
    Nov 2006
    Default Handbrake question
    Well I have just snapped my handbrake cable.
    It felt like it broke up near the lever, so my question is how much am I looking at to replace it and is it an easy fix or is it a pain in the butt.
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    The cost of a cable???.....
    Get Troy or CSP to fit it for you.
    I like my roo well done
    Supercharged VX S
    Nov 2006
    I will be able to fit the handbrake cable over a few beers with some mates, I was just after a rough price on how much the cable was going to cost to buy. Is it a 2 piece cable or not, will I have to take out my centre console or not, any advice prior to me starting would great recieved.
    VN Calais S2
    Sep 2009
    Melbourne West
    by memory its a one-piece cable, either end head off to the wheels and the centre of it hooks over ur handbrake mechanism
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    Quote Originally Posted by badaz View Post
    For the interior part, take out your front seat (but make sure you disconnect the battery, and wait 5 mins so the air bag light doesn't come on your dash), this makes it really easy to get to the handbrake. There's 2 bolts to hold the handbrake in, unscrew them, there's also a wire connected to the sensor (to say if the handbrake is on or not), just pull that out. There is also a little nut over your handbrake cable, seeming yours is snapped i'd leave it on so you can try pull out that half of the cable.
    i changed my handbrake to a leather one and i found it easiest when i took the seat off.
    HSV +6
    Mar 2006
    Mornington Peninsula
    Total noob here, how hard are they to tighten? Mine has become very slack.
    walking
    Feb 2009
    Northern beachesNSW
    get under your car and theres a bolt (follow the cable from your brake) tighten the bolt and your on your way
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    Quote Originally Posted by crouchy View Post
    Don't tighten it too much though otherwise your brakes will ride meaning that when the handbrake is off, the brakes will still be touching
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    The handbrake is tightened from inside the car next to the drivers seat.. remove the rubber cover and tighten the 10mm nut and it will change the free travel of the handbrake lever
    HSV +6
    Mar 2006
    Aha which is it? In car or under? Wheres CommodoreNut when you need him :P
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
    Quote Originally Posted by And_ROOS View Post
    Its in the car under the cover beside the drivers seat..
    There is also an adjustment at each wheel too but that normally only needs looking at when there is no more adjustment at the handle..
    walking
    Feb 2009
    Northern beachesNSW
    Pete SS's Avatar
    Pete SS is offline Resident Pomme
    VU SS M6
    Oct 2008
    Sydneys East
    Mine only works on one wheel. Can I adjust something on the one that dosen't work or do you recon something needs replacing? To be honest I don't even know how they work, is there a drum behind the disc?
    walking
    Feb 2009
    Northern beachesNSW
    Pete SS
    stolen from Brakes: Drum vs. Disc
    this doesnt help your problem but answers the other question
    They were called drum brakes because the components were housed in a round drum that rotated along with the wheel. Inside was a set of shoes that, when the brake pedal was pressed, would force the shoes against the drum and slow the wheel
    disc brakes use a slim rotor and small caliper to halt wheel movement. Within the caliper are two brake pads, one on each side of the rotor, that clamp together when the brake pedal is pressed
    i figured you couldnt be ****ed reading the whole page and i couldnt be ****ed explaining it so i just stole it instead might be easier to understand with pictures.. google it
  15. #15
    Pete SS's Avatar
    VU SS M6
    Oct 2008
    Sydneys East
    sorry, I'll make myself clearer. I'm not sure how the VU handbrake works.
    I know how discs and drums work but wasn't sure how holden had their setup. Some manufacturers have a disc and drum setup, where the disc works with the footbrake and the drum only is used for the handbrake. I wondered if this was the setup on the commodores.
  16. #16
    VU S Pack
    Feb 2009
    Quote Originally Posted by Pete SS View Post
    Yeah that is how holden have set it up on the VU's
  17. #17
    VX acclaim S2
    Oct 2009
    take off your back wheels and there will be a clip on the rotar, unscrew that and adjust ur handbrake lever accordingly by moving the adjustment disc.. make sure they arnt to tight however otherwise like it was mentioned it will brake while your not meaning... also next 2 the drivers seat is the easy way of adjusting and is quicker
  18. #18
    Ripcell's Avatar
    Ripcell is offline R8 FTW!!!
    324rwkw MY06 VZ R8 Maloo M6
    Apr 2006
    East Melbourne
    mine broke last month, $31 for the cable, not hard to change just fiddeley being above the twin exhaust in your 6 shouldnt be too hard tho
  1. handbrake help please.
    By barely legal in forum General
    Last Post: 14-08-2008, 08:36 PM
  2. vb-vc handbrake
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-10-2006, 08:55 AM
  3. vn handbrake
    By vn_lexcen_s2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 06:31 PM
  4. handbrake help
    By magnum44 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-07-2005, 09:28 PM
  5. VY/VZ Auto & Handbrake handle Question
    By Camotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2005, 08:51 PM
