Results 1 to 2 of 2
Thread: VT Ecotec not starting...
    1997 VT Executive
    Dec 2008
    Default VT Ecotec not starting...
    Hey all, I bought a VT Executive recently and it won't start...
    When I first got it I had a problem starting it but it was intermittent It would crank over but not fire, but eventually it would start. It progressively got worse and now won't start at all. I also found out there's no spark
    Any ideas as to what it might be??? A few things that have been metioned by some people include the crank angle sensor, the coil pack module or the key itself.
    KJ
    VTII Exec V6
    Mar 2010
    hi there, i had a similar issuse with my VTII you'd turn the key it would crank a couple of times and then stop cranking all together, then you'd try to start it again and it wouldnt even turn over, finally got it going got home and the central locking on the key wouldn't work. flat key fob battary not sending a long enough signal or no signal at all to ecu $100 later no starting issues.
    It also sometimes turned over with out firing.
  1. VS ecotec, not starting, after no problems and just filled up car
    By HICOMPVN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2009, 03:51 PM
  2. Pre-Ecotec with Ecotec Performance Upgrades
    By JA2Z in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2009, 10:06 AM
  3. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  4. WTB: RECO VS ECOTEC or ECOTEC STROKER
    By Cursed CX8 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-09-2008, 12:15 AM
  5. VS and VT ecotec Starting issue
    By yyg998vsute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2006, 11:38 PM
