I've done it to the front of my car full suspension bush redo. I find it does make the steering more sharp and doesn't squarm as much under cornering. However it does and will place more stress on components because the stresses aren't relived by the flex in the bushes because there is non.
These are more prone to failure in commodores and should be done in conjunction with the other bushes you linked to
Commodore VT VZ Strut Rod to Chassis Bush Kit NOLATHANE - eBay Other Suspension, Steering, Suspension, Steering, Car Parts, Accessories, Cars, Bikes, Boats. (end time 27-Oct-09 21:58:53 AEDST)
VYII Calais L67
Thanks for the replies, I had the Pedders check and one of the bushes has delaminated. The guy showed it moving on the test equip.
Do you think I should just buy them from Holden?
no you need rubber i work a pedders
use rubber in front except radius rod bushes and get them sports set
Why rubber? Why not urethene?
urathane only works good in some spots
plus rubber donsent need moly grease that eats urathane away
plus rubber at lower iners if done up at ride hight helps with leveling
