Results 1 to 21 of 21
Thread: temp flashes hot and then goes bak to normal temp?
    VT-S
    Oct 2009
    Default temp flashes hot and then goes bak to normal temp?
    got a vt series 2 where since i got it serviced about 3 months ago every now and again the temp gauge will flash up hot n then just as quick will go back and sit where temp shuld sit, in the service the mechanic changed the thermostat i am thinking this may be a faulty part as before the service it never happened. has any one else ever experianced this?
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Yes, ....take the car back to the mechanic and tell him that you suspect a faulty thermostat has been fitted.
    crazywog's Avatar
    crazywog is offline VS V6 ECOTEC KING
    my fully shick holden bro
    Oct 2006
    In my fully shik holden bro
    yeh i had the same happen in mine bursons
    RAJAB RACING
    FullBOOST
    PRESTON AUTOMATICS & DIFFERENTIALS
    etstreet.com
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    wat brand thermostat did u use?? delco i think the brand is that have been found 2 have faulty thermos new.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VT Executive S2
    Jan 2009
    stupid question but have u checked if there is a leak in the system because the exact same thing happened to me 2 weeks ago turns out the system wasnt bled properly and there was a small leek.
    VT-S
    Oct 2009
    yeh had a smal leak fixed that, blew a hose fixed that aswell now, still happening and no longer losing any coolant so ill give the mechanic a call as soon as i get the chance, thnx for the help
    VT 2
    Nov 2008
    It actually sounds like a faulty temperature sender to me. Thermostats tend to fail by going open or going closed and then staying that way. So the gauge wouldnt fluctate, it would go red and stay there.
    I think a faulty temp sender or a short in the temp sender cables.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds like you have an air lock. I bet it flashes hot at idle or slow speeds? When the revs get up it goes back down?
    Visit my Facebook page
    VT-S
    Oct 2009
    its done it at idle, low speeds, and low revs, havnt noticed it happen at high revs, mostly just happens when casually driving to shops and things like that
    vx executive - Trumph TR6 - Toyota surf
    Jul 2008
    Tauranga NZ
    Quote Originally Posted by shifty_90 View Post
    Does this happen when warming up from cold or when the engine is already hot ?
    rch-13z's Avatar
    rch-13z is offline im rick james..... bitch!
    VT Exec
    Jan 2008
    South-West Sydney
    Quote Originally Posted by Not_An_Abba_Fan View Post
    When you say air lock, you mean bubbles of air in the cooling systems? had this issue a couple of weeks ago, just when sitting at lights it would say it's hot then i'd take off and it would drop off.....
    VT-S
    Oct 2009
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    I recon NAAF has it in one.
    bubble in thermostat... need to bleed the cooling system.
    Similar issue when I had my thermostat changed in the VX.
    Easy fix is run the car, undo the screw above the thermostat until it starts releasing air, do it back up when it starts spitting alot of coolant.
    Alst make sure you do this with the heater on to full heat and let the car run for like 2-3 min before hand so any bubble in the heater adn heating system have a chance to move through the system to the thermostat.
    Good luck.
    VT-S
    Oct 2009
    thanks jest might give this ago on weekend, not looking forward to spending any more money on a bloody mechanic since its bin back to him once already since the thermo change, it doesnt seem to be a major problem it wouldnt do any damage to anything would it?
  15. #15
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    shouldn't cause any huge issues, but I would have a look at it sooner rather than later.
    Because it throws out the engine temp sensor there is a chance the computer will shut the engine down on you if it thinks it's running too hot.
    I drove my car around for a week before I fixed it... but yeah... see how you go this weekend and let us know.
    VT-S
    Oct 2009
    would any one be able to post a pic of the engine bay n highlight the thermostat so i can try the bleed out of the air bubbles and see if that fixes my problem, jus dun wanna unscrew the wrong thing?
  17. #17
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Without a pic, follow the top radiator hose to the engine, where it connects is the thermostat housing. On top of that is the bleed screw, looks a bit like a grease nipple with a hole in it.
    Found a pic....
    Attached Thumbnails Attached Thumbnails temp flashes hot and then goes bak to normal temp?-bleed-screw.jpg
  18. #18
    VT-S
    Oct 2009
    VT-S
    Oct 2009
    jus lettin u know i tried the bleeding air from system through the thermo and so far so good havnt had any problems since weekend taking it out tonight for a bit so if i have any more problems ill let u know
    thanx for all the guys
  20. #20
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
  21. #21
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Easy way to test the gauge is......when starting the car, put the car into diagnostic mode via the trip computer buttons. This allows you to get into more features of the trip computer and allows you to see the coolant temp in actual degrees. So when the gauge goes skywards, you can check to see if the digital is doing the same also.
    Just an idea
  1. Normal Temp On Vl
    By BJOHNB in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-01-2012, 06:11 PM
  2. normal running temp for a VT 5L? and temp gauge..
    By mike49 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 12:57 AM
  3. Normal Temp for a VS
    By Acclaim96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2008, 09:43 AM
  4. Normal Operating Temp
    By fitykemp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-01-2006, 08:53 PM
  5. Normal runnig temp?
    By comtim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2005, 10:00 AM
