Results 1 to 15 of 15
Thread: rockers and push rods
    vt commy
    Aug 2009
    Lightbulb rockers and push rods
    Hey guys
    I have a 2000 model v6 vt commodore and its the first time im doin up a car so all help is realy appreciated.... iv been doin a little reserch on the net and found some 1.97 hybrid rockers and im puttin 5/16 push robs in. But was just wonderin if i have to get anythin customized to make them fitt....
    dynoryder is offline Banned
    vp executive wagon
    Oct 2009
    A.C.T.
    you should buy the rockers and rods for your model
    which is ecotec
    ive seen 1:1.9 ratio but all you need is 1:1.6 rockers with the right cam
    i would get the rockers from the shop you get the cam from
    vt commy
    Aug 2009
    Thanx mate ... this prob sounds like a stupid question but wat is cams and wat do they do lol sorry like i sed neva done up a car let a lone gone near an engine lol
    vp executive wagon
    Oct 2009
    A.C.T.
    the cam moves the rockers up and down it dose this with cam lobes there like eggs look it up
    if you going for speed i would sugest buying a car already done
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Go the the Mace Engineering section, in the sponsors area, v6 modifications. They have 1.98 rockers with pushrods included, much cheaper. As a beginner, these rockers are better as you can do them yourself or cheap installation than a camshaft. Camshaft is cheap same as rockers, but expensive to install and then tune it. On Vt hopefully you can use a Chip instead of tune, check on the Crow Cams website. Mace have those packages as well,
    vt commy
    Aug 2009
    Thanx heaps 4 the info... any more info on the questions that i asked ( do i need to customize anythin to put these push rods and rockers in )
    VT 2
    Nov 2008
    I have done MACE 1.98 rockers on my VT 2 v6. Easy as to do.
    No customisation neded. No modification needed.
    Only thing to remeber os make Absolutley sure you cover both ends of the pushrods, the rocker seat, the rocker pushrod face and the rocker valve face with the supplied pre-lube when you assemble.
    Safety says by a torque wrench so you tighten the bolts to the correct torque.
    vp executive wagon
    Oct 2009
    A.C.T.
    so if you buy these rockers do they come with shorter rods if so what is the point it wont lift the valve any further
    the best way to get more valve lift is a cam usally only repalce rockers if you want strength in the valve train
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    The pushrods aren't shorter, they are stronger and thinner so they don't hit any overcast metal in your engine.
    Yes the best way to get more lift is a cam, if you have the money. The cheapest way to get more lift is higher ratio rockers.
    Ronald Reagan (1986)
    VT 2
    Nov 2008
    I disagree. The best way to get more lift is the rockers. yes a cam can provide more lift, but to do it with a cam changes duration as well as lift. This changes the engines airflow characterists entirely.
    it may change them for the better, but there are sacrifices there in terms of idle quality, economy and driveability as well.
    Changing the rockers gives more lift, without changing any other engine characteristic. You don't need a tune to get the most out of them.
    The pushrods are the same length, the contact point is moved in towards the post a bit, so that it multiplies the amount of lift (think push down on top on valve stem) a little.
    Standard ratio at factory is about 1.6 I think. I'm running 1.98's and there are up to 2.15's around for the v6 ecotech.
    vp executive wagon
    Oct 2009
    A.C.T.
    Quote Originally Posted by Tsunamix View Post
    would the 2.15's coilbind the springs if how close do they come if you know and do they make 2.15"s for buick sixs
    Jul 2006
    Quote Originally Posted by dynoryder View Post
    Not for buicks yet, and no should not give coil bind. Stock modifided rockers are known for retaining factory characterisitcs over newly designed such as the YT's. I have been running YT's 1.95 for over 3 years now, no coil issues. Mace however are looking at packaging the 2.25 with modified heads, to cater for the extra lift and flow. Something i am looking forward to.
    VX Berlina
    Apr 2007
    Fair point. Though depending on the cam their may not be any noticable degrading of idle quality, economy or driveability.
    The only bad thing about higher ratio rockers is that they increase pressure on the camshaft, only slightly, but it is there. Still people have been running them for years without destroyingcam bearings, or damaging cams.
    To the OP, go for it and let us know how it went.
    vp executive wagon
    Oct 2009
    A.C.T.
    big lift cams can idle well cuz they dont have overlap
    overlap is what stuffs up idle
    forced air engines cant have overlap in the cam so they have max lift cams that nearly coilbind
  15. #15
    vt commy
    Aug 2009
    Thanx heaps 4 all the info guys... bit short on money atm but will do it soon. Hopefully... and i will be bak on to tell u how it all went ... again thanxx
  1. bent push rods
    By Phat VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2009, 02:40 AM
  2. Push bikes
    By HAZZA-VN in forum The Pub
    Last Post: 30-08-2009, 11:43 PM
  3. push rods for a 5.7
    By loveless in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2009, 08:42 AM
  4. what amp will push these subs better?
    By nips69 in forum Car Audio
    Last Post: 05-12-2008, 05:28 PM
  5. need a push
    By kowan in forum Jokes/Humour
    Last Post: 27-06-2006, 11:52 PM
