Results 1 to 2 of 2
Thread: vt level 3 cluster problem (help)
    vt s v6 supercharged
    May 2008
    Default vt level 3 cluster problem (help)
    hi everyone, i have a vt supercharged v6 with trac control with a single cluster, i got a vt berlina v6 level 3 cluster and installed it everything works except for the trac off light, the trac still works and can be turned off and on like normal but the light doesnt work i have changed globes cleaned terminal etc , im not sure if the berlina had trac, but i was informed it shouldnt matter, should just plug in and off ya go, any ideas what is going on, also if i put my single cluster back in the light works ??????
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    Quote Originally Posted by dcjacko View Post
    you could have just replied to your first thread, no need for a new one but oh well lol.
    Have you taken it to holden yet to get it programmed for your car?
    You stated your air bag light was coming on (in your other thread), so i'm going to assume you haven't then.
    Shouldn't cost too much and should only take them 30 mins or so, if its anything like mine (i put a 3 window cluster in my car too) you should have a cross on the right window in the top left, after i got the cluster programmed for the car that went away too.
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. vt level 3 cluster change problem vt s pak
    By dcjacko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2011, 08:59 PM
  3. level 3 cluster buzzer problem...
    By sniperknight in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2009, 07:21 PM
  4. Dropping Level 3 Cluster into unready Level 2 ready VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 03:56 PM
  5. Problem Level 3 Cluster
    By ninjagarth in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2008, 10:48 AM
