Hi, my mate has a VT Auto with the v6 motor and whenever he tries to do a burnout he'll apply brakes and no matter how little amount the engine will not rev past 2000rpm. Burnouts were not a problem in his old vt. He does have a problem with his crank angle sensor but im not sure if this is related. Any ideas would be appreciated, thanks
No, there is nothing wrong. They all stall up to about 1800-2000. If he cant turn the tires, probably means he's not making enough power + IRS.
ah ok thanks, his car does have over 300k so that wouldnt help the power problem much![]()
Disable ABS :P
just give it a gut full you pussys or go home and dont do burn outs if your worryd bout braking your car
cars arnt made for this abuse so just abuse the car and it will have a hissy fit (that means smoke comes out)
