Results 1 to 6 of 6
Thread: VX Power window button sticking
    VX S-Pac
    Sep 2009
    Default VX Power window button sticking
    Hi guys,
    The power window switch that operates the front passenger window from the center console in my Vx is sticking i.e when you push the switch it stays in the down position and won't come back up unless you flick the switch back up. the window itself operates fine it's just annoying if you only want to crack the window open a tad as the switch always sticks. Will i have to take a trip out to a wreckers to get a new part?? Anyone else had this problem?
    VX Executive
    Jan 2008
    VT spac super6
    Nov 2008
    Riverton sa
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    Pull the switch out of the housing and pop the cover off. Give all the inside a clean with some metho or similiar and you will prob fix it.. What you will find is that people have splashed coke and O.J down there over time and causes them to foul up..
    vt calais lx torana
    Dec 2008
    gippsland vic
    as boganv8 says but be careful when yu pop the cover off the switch it has little pegs and springs that can bounce out and you will always find they bounce under the seat rails... good luck
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Another common which would more likely b the case is those "pegs" that mojo is talking bout, over time the bottom of them get rather hot from sittin on the metal contacts so they start 2 melt down.
    Wen they get 2 a certain point they wont b able 2 use their own spring 2 push themselves back into the default possie so if thats the case find some rear switches from the wreckers n swap them over. The rear switch pegs r the same as wats in the main power window block so it'll b cheaper 2 use those.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  1. Power Button???
    By the_ozz_man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-06-2008, 06:43 PM
  2. LEDs in traction control button and rear power window switch
    By Jom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-03-2008, 05:05 PM
  3. electric window button
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2007, 02:40 PM
  4. Window Wiper Wash Button thing : /
    By Stephen_Vn_Exec in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2007, 02:12 PM
  5. power window button VTII
    By scbh81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-12-2005, 05:53 PM
