Results 1 to 3 of 3
Thread: Cruise control in a base model!! **is possible**
    VX Lumina
    Sep 2007
    Default Cruise control in a base model!! **is possible**
    Hi guys, i am here to confirm that i have succesfully put cruise control in my Series 1 VX lumina!!
    i have the instructions here if anyone is interested. It is fairly easy if you got the parts.
    You will need:
    The cruise control module.
    The cable from the module to the throttle body.
    The brake switch
    The indicator stalk.
    There is a plug hanging off your drivers side shock tower wiring loom - it is a brown plug - this plugs into the back of the cruise control module.
    the Module bolts onto the tray next to the ABS module - youll see the empty try that im talking about.
    The cable plugs into the back of the module, runs back along the firewall, around to the passenger side shock tower and then to the throttle body.
    On the throttle body you will see where the accelerator cable is clipped on, just near it is another place to clip a cable onto - this is for the cruise control - clip the cable on there.
    engine bay is done.
    Remove the upper steering column cover and unplug the blinker stalk - remove.
    place cruise control stalk in, plug in to where the original was and locate a smaller plug and plug in the small wire loom that is on the stalk - replace steering column cover.
    remove the fuse panel flap from under the steering column and locate the back of the brake pedal (look down the steering column) you will see a switch plugged in and a hole above it - this hole is for your brake switch which deactivates the cruise control when you push the brake pedal.
    locate the plug that is taped to the steering column and plug the new brake switch into the rear most 2 plugs on the switch - if you plug it into the front 2 plugs the system wont work.
    secure the brake switch into the hole and adjust so that:
    when the brake pedal is not being used the switch is pressed in.
    when the brake pedal is pushed, the switch is let out.
    you may need to road test a couple of times to make sure the system is deactivating correctly when you apply the brakes.
    Cruise control is now installed and ready to go.
    if you dont have the plug hanging out near the drivers shock tower - you cant put cruise in without having to wire the whole car for it.
    Fuses should already be in for cruise control too.
    instructions thanks to davway.
    just thought id help people out by posting it!
    Sep 2004
    i thought all vt and vx came out with cruise control standard let alone a vx...
    VT_sleeper's Avatar
    VT_sleeper is offline Don't G-Tech in reverse
    Black VX S II - Supercharged
    Jun 2008
    SE Suburbs of Melbourne
    I think it depends if you have ABS or not. I have a vt EXEC with out ABS/Cruise control and I'll just had another look for the wires near the strut tower and near the stearing column but I can't find any.
    I don't suppose you can take photos of the wire locations and post them up?
    I wonder what my alternatives are... I have spoken to holden spare parts and they have said there is a kit for $370 or there abouts, I asked them what parts where in the kit and they couldn't tell me, also asked if it would fit an EXEC with out abs and he tells me this kit is for this VT EXEC II V6.. but I don't know if you require the ABS module first... hrmm
  1. vb commodore base model options
    By c2105026 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-09-2009, 06:18 AM
  2. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  3. fitting high level options on base model
    By notthekingswood in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2008, 08:56 AM
  4. VY SS dash into a VY V6 Base model ?
    By OZ38 in forum Electrical Wiring / Questions
    Last Post: 22-02-2007, 12:21 AM
  5. ss/hsv bits on a base model.. am i a hypocrite?
    By fluxxx in forum General Discussion
    Last Post: 01-12-2006, 03:00 PM
