Results 1 to 4 of 4
Thread: VX Boot Lock Broken - How fix it.
    2001 VX Commodore Equipe
    Jun 2003
    Talking VX Boot Lock Broken - How fix it.
    Guys,
    My boot went the usual 'click' then 'clunk'.... it wouldn't open.
    I had a look and the metal rod (10cm long) inside the boot lid attached to the actuator had sheared off at the boot lid latch.
    I was thinking... off to holden $$$$
    After looking at it I figured how to repair it.
    Hope these steps address your problem:
    1. Opened the back seat to release the boot with the emergency catch
    2. unscrew the two screws holding the silver latch.
    2.a. unhook the emergency release cable from the latch (stow it so it does not pull pack to far. WARNING: Do not pull the emergency release tag near the back seat when it is unhooked from the latch - it may end up behind the boot liner).
    3. unscrew the two srews holding the actuator motor inside the boot lid (undo the power cable prior to removal).
    4. unclipped the rod from the actuator (it will push out of the white end piece).
    5. took 1 x metal coathanger (the type from the dry cleaners)
    6. cut 12.5cm of coat hanger.
    6.a. you need a 10.5cm straight piece with the other ends bent at 90 degrees (off centre - check the current rod as a guide). I just measured the old one and matched up the bends/angles
    7. place the replacement rod into the acutator end, refit the actuator and hook the other end of the rod into the boot latch and rescrew it in.
    8. sorted!
    I can post some photos if it helps. Though it is very easy once you have a look at it.
    Bart
    commodore vx
    Jul 2010
    Only one thing that I would like to do re this advice from Bart and that is to buy him a beer. It worked a treat.
    Cheers Bart.
    Grando
    VR V6 Turbo
    Apr 2008
    Thanks for the help, mine just broke so replaced the wire rod following your instruction and good as new
    VT BERLINA
    May 2011
    East Hills, Sydney
    wish i found this like a year ago ... gollllddddd .
  1. Broken Lock Button
    By mainpath in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-10-2009, 10:02 PM
  2. boot lock??
    By PUSHIN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-07-2009, 03:18 PM
  3. Broken door handle with child lock on
    By Psycho in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-05-2007, 08:34 PM
  4. Broken passenger door lock
    By VRFURY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-04-2006, 03:01 PM
  5. VT boot lock
    By tc0707 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-09-2005, 02:44 PM
