Results 1 to 11 of 11
Thread: Cat pee in the heater??
    nee
    nee is offline
    2000 Commodore S/W
    Oct 2009
    Default Cat pee in the heater??
    Greetings!
    Our 2000 Commodore wagon smells terribly of cat pee! I'm almost certain a cat hasn't got inside to do its business. Is the air inlet for the heater up by the windscreen wipers? If so, I suspect the cat is leaving its mark on the windscreen and urine is trickling down into that area, where the vents are. I'm just not sure of the location of the inlet, or the best way to clean it if this is the case.
    Many thanks!
    IanG
    vt v8 sv exec 044
    Oct 2008
    bit of coolant on the ground will fix the cat up. (na dont do that it will kill the cat)
    u can get a deodoriser to put through the system will help get rid of the odor and wash all external parts of the car as other cats will piss on it now aswell .
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by nee View Post
    Greetings!
    Many thanks!
    IanG
    If you lift the bonnet you will see a vent on either side up near the windscreen, they usually have a few leaves and stuff on them. I think the vents are also part of that plastic shroud where the windscreen wipers are.
    MY RIDE
    Dec 2005
    Western Suburbs
    they dont really piss like a dog though they sort of spray it everywhere especially when there marking there territory
    nee
    nee is offline
    2000 Commodore S/W
    Oct 2009
    Thanks for the quick replies. I've been Googling around and a couple of people have mentioned that leaking coolant can smell like cat pee. Anyone experienced this?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Leaking coolant has a slight smell but nothing as repulsive as cat pee.
    MY RIDE
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    and this is why I am not a cat person.
    As people have said, you can put a deoderiser through the system which should help but probably won't disappear all together. I had a cat do it's thing on my car and it took like a week before the smell was completely gone.
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    I dont think , its cat pee you are smelling. More like coolant, by the sounds of things your heater core is starting to leak. Best thing to do, is get those holden crush tablets and put it in with your coolant
    NEVER LATE IN A 355ci
  10. Default
    it's not so much the cats fault as the owners. if they were a responsible pet owner and got the cat neutered in the first place it wouldn't be spraying everywhere. but most people aren't.
    it's going to take a long time for that smell to go away, unless perhaps you have a leaking heater core and it's actually coolant and not cat piss (coolant can smell pretty bad as well). open up your coolant reservoir and take a good sniff. see if that's what your car smells like. also check the passenger side carpet for any wetness/mould.
    EDIT: BT1-355 got there first
    Quote Originally Posted by zai View Post
    I am not sutpid
    VT Calais V6
    Aug 2007
    My sisters cat used to spray the front windscreen of cars and it would get into the air vents, so it could be cat piss you are smelling for sure
  1. heater tap
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2007, 09:52 PM
  2. vl heater box will fit in a vh??
    By lil_oneblue in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-02-2007, 07:05 AM
  3. Heater
    By pj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2006, 09:40 PM
  4. Heater TAP???
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2005, 11:16 PM
  5. Heater
    By gospeedracer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2004, 04:00 PM
