Results 1 to 6 of 6
Thread: fuel sender
    VX berlina ecotec/ vy ss ute
    Sep 2009
    Default fuel sender
    Hello,
    Just recently i replaced my fuel pump.. and fuel gauge was reading correct with the warning light coming on with 50kms to go. but since i have replaced my pump it doesnt read correct goes empty with a 1/4 of a tank? can i fix this?
    thanks
    Vt Clubsport
    May 2009
    mate you will most likely need a new sender, sounds like you've let it run too low on petrol and its conked out on you. make sure all your lines are fine too.
    Sep 2009
    yeah it did conk out on me coz i didnt no what it was so raa come out and said u have no petrol gay how much is a new sender?
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Go to holden, hand over 25buck and they will re-calibrate the sender for you.
    Had a similar issue but the other way round, guage showed 1/4 tank when I was running on fumes... I ran out of fuel twice before I worked out wtf was going on lol.
    Good luck.
    FPV GT-P Boss 335 & 2000 VX Berlina 5.7lt (toy)
    Jul 2010
    Dalby
    So, they can be re-calibrated Jester??. Is this done though the ecu or cluster??
    showbags's Avatar
    showbags is online now Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    You can re-calibrate though your cluster.
  1. VN and VR fuel sender units different
    By GTP 85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2009, 02:56 AM
  2. VX LPG Fuel Sender
    By deserthead in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2009, 09:59 PM
  3. Fuel Pump and maybe Sender???
    By dj_eddie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2008, 08:48 AM
  4. fuel sender problems (i think)
    By bush_basha in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2008, 08:47 PM
  5. Fuel Sender Unit
    By micko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2004, 12:33 PM
