Results 1 to 13 of 13
Thread: how can i tell if i have a LSD
    BJ31OS's Avatar
    BJ31OS is offline Supercharged VT
    Supercharged Series 2 VT
    Sep 2009
    Newcastle
    Default how can i tell if i have a LSD
    Hi guys
    Just wanting to know if there is anyway i can tell if my VT S pack came with an LSD as it was an option, is there a way i can get under the car and look is there a marking sorry if this is a silly question.
    vt acclaim gen 3
    Jul 2009
    vic
    there has been many threads covering this topic a quick search should give you all the info u need mate
    BJ31OS's Avatar
    Sep 2009
    Newcastle
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    MattyC's Avatar
    MattyC is offline Just cruisin bro
    VT Calais 5L
    Jun 2009
    go on someones front lawn and accelerate then go look at the grass
    Third Ride: 2002 VX SS 5.7L V8
    Second Ride: 1998 VT Calais 5L V8
    First Ride: 1999 VT S Series II
    VT S S2
    May 2009
    ey mate simple get under your car look at the diff ussually the LSD diffs have a high performance tag on it, which is easy to see and my mates by memory wrote LSD on it
    VN_chris is offline Banned
    VN Commodore S
    Jul 2009
    Wollongong
    easy way to tell, harden the f*** up and get on the break for a few seconds and if it kiks to the side and goes up the street side ways then its an LSD if you just stay on the exact spot and smoke up a hell of alot then its a piece of shit diff and you need to get an LSD installed.
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    jack it up and turn one wheel by hand, if the other one turns, it is an LSD, if the other wheel doesn't turn, it a single spinner or a screwed LSD, usually a single..
    VS S Maual 5 Speed Ute
    May 2009
    Just light it up burnout.... I mark on the road no lsd. drifting with two marks you car has been fitted with lsd
    1996 VS S Ute -5 Speed Manual
    Extractors and sports exhaust system
    VY CV8 R 18 Inch Wheels, Stage 4 Memcal Chip
    3.89 Diff, Lowered, CAI
    shiftySLE's Avatar
    VH SLE, VZ Acclaim
    Jun 2009
    single spinners will limo too if there isn't enough traction like on on grass or in the wet.
    vs acclaim II
    Aug 2009
    i have a vs acclaim im 99% sure its a single spinner, but if i sit on the brake it limos almost every time i think my diffs just ****ed lol
    MattyC's Avatar
    VT Calais 5L
    Jun 2009
    Quote Originally Posted by mrsn8r View Post
    cant you achieve that by welding a normal diff or something?
    shiftySLE's Avatar
    VH SLE, VZ Acclaim
    Jun 2009
    not if it LSD'd almost every time, a welded diff is the tightass way of having a spool, it would LSD every time unless the weld breaks
