Hi,
will changing rear shocks help with a sagging rear end or do i need to replace springs as well.
how hard is it to change springs and how much?
thanks in advance.
You'll need a bit more detail than that.
Sagging how?
Inwards (camber)
Have you done high k's? springs gone baggy?
Springs are easy to replace on rear, with no hassles if you are keeping your ride height the same - not changing shocks
done 190,000 kms.
would like to keep original ride height.
tyre wear almost even acroos all rubber.
On a live axle car, no, they make no difference, but on IRS however, they can make the car sit a bit higher. They are probably stuffed anyway, so yes, replace them.
